Question about Samsung Digimax D53 Digital Camera
Samsung Digimax D53 camera
Camera is off, lens is still out, and when you turn it on it beeps and turns back off. I have tried new batteries,but it's still doing the same thing. Do you have any suggetions.
  • 2 more comments
  • Anonymous Dec 16, 2007
    the same thing happened to me,but when i turn it on....it says there is a dead battery....but they are brand new
  • dretaja Dec 20, 2007
    This camera is only one year old and will not come on. It reads "low battery" even when I buy new batteries. I've tried different batteries and none will work. Is there specific battery that need to be used?
  • Anonymous Dec 22, 2007
    Lense won't go back in and it beeps when I turn in on. Have put new battereies in but this doesn't help.
    I took camera apart. Then I used rubbing alcohol around the lense where it retracts back in. Then I used a high quality oil used on Grandfather and other mechanical clocks to oil the camera. The oil does NOT attract dirt. Then with the camera laying down with lense pointing up, I turned the camera on and off quite a few times to help work the oil down into the camera into the gears. It seems to be working now.
Lenses are jammed. send it to a service technician. sorry.
Posted on Oct 24, 2007
SOURCE:
Samsung Digimax D53 will not stay on
This is most likely a lens failure. Try contacting your manufacture if your camera is still under warranty. If not, try contacting your local electronic repair shop to get it fixed. Hope this helps!
Dec 07, 2009 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
Good batteries ...turn it on and it beeps 3 times, lens does not
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 01, 2009 | Samsung Digimax D53 Digital Camera
3 beeps
had the same problem with my D53 eneded up buyin a new camera pulled the D53 out the other day was going to toss it then i noticed the lense was just a lil crooked i played with it a freed it up camera works great now
Sep 23, 2008 | Samsung Digimax D53 Digital Camera
D53 camera will not fully turn on...help??
If you've tried the suggestions for similar problems on here - use NiMH or lithium batteries (not alkalines), then it may be a warantee job. Afraid I don't have any other suggestions.
Sep 05, 2008 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 beeps and shuts off
I had the exact same problem. Camera turned on but turned off soon after, with lens still outside. I noticed the lens was crooked as if it was stuck. I pulled it out and I heard it click into place, for a second I thought I had broken it. I then turned it on and everything was working again ! Whew ! Problem Solved :D Good luck!!
Mar 15, 2008 | Samsung Digimax D53 Digital Camera
Problem with startup
my samsung d53 issue is .when u turn it on it beeps 3 times and shuts off. thats all it does.... cant take a picture its like the batteries are low.But they are not. what is wrong. like new! jimmy
Jan 27, 2008 | Samsung Digimax D53 Digital Camera
Help
Try rechargeables or oxyride batteries, not alkalines. Hope this helps!
Oct 26, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53; 5.0 megapixels
Mind did the same thing. Try taking out the memory card. If it works after that, you'll have to buy a new memory card.
Oct 16, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Digital Camera Logo
166 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
