Ink Tank error message displayed. It has been working on these tanks (not Canon) ok & tanks see full. Any way round this without having to buy expensive Canon tanks?
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041
Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052
Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071
The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130
The following ink tank cannot be recognized. U043 U140 U150
The following ink has run out. Replace the ink tank. U163
There are no photos in memory card
Contact the support center or service center for ink absorber replacement. Press OK to continue printing
Ink absorber full. Service required
Timeout error has occurred
The device may be incompatible. Remove the device and check the manual supplied with the connected device
An unsupported USB hub is connected. Remove the hub.
B200Printer error has occurred. See the manual
**** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
