Question about Refrigerators
Ge tfx20jr side by side refrigerator
It is not cooling anymore and I know nothing about where to begin to look. Can you please help????
  • 5 more comments
  • gibsigrl Feb 11, 2008
    this morning my fridgidaire frs26r4aw5 made a really loud noise coming from the freezer (I think) then I realized that my food was starting to thaw. I removed the food from the freezer and you could hear the fan come back on but it goes off again. Also at the same time the water dispenser stopped working. What could be going on.
  • Anonymous May 03, 2008
    refrgerator not cooling freezer working fine
  • Anonymous Aug 17, 2008
    Fan running cleaned coils underneath fridge
  • bigR757 Aug 17, 2008
    The refrigerator is not cooling like it should, but the freezer is working fine.
  • sspeck70 Nov 10, 2008
    I have the same problem. My GE tfx20jr is working fine on the freezer side but stays around 60F on the fridge side. I recently purchased it new from a very nice older couple who said it was working fine. They were using it, actually. I have played with moving the temp controls to no avail. It also is veeerrryyy slow to make ice. I have checked the water flow to the unit to make sure it is sufficient. I was wondering how important the levelness was. It looks to be a little unlevel. I can fix that easily just wondering if it could be a factor.
  • dull_jason Feb 21, 2009
    My fridgidare is humming and neither fridge or freezer side is cold can someone tell me whats going on.
    maybe compressor
  • hairless1500 Apr 13, 2009
    should I replace the defrost thermostat or the heaters?
    Thanks
I was having the same problem and found that the drain hole on the freezer side at the bottom was clogged. When the condensation drips it should drain through that hole. Since it is clogged the water builds up and leaks out the side of the refrigerator. Here is how to fix it:
1. Check to make sure you see the hole and that it is clogged. You will know it is clogged if water simply sits on top of the hole and doesn't drain through it.
2. Unplug the refrigerator and get a flashlight - I used the little cute one on my key chail :-)
3. Go to the back at the bottom right and remove the vent cover. It is just a few screws.
4.On the right you will see a plastic pipe that connects to the rain drain inside the freezer.
4. Simply disconnect the pipe and remove it. The pipe is bendable so do be afraid to bend it if you need to in order to remove it.
5. Clean out the pipe with hot water. You will need to tap it in the sink to make sure all the "gook" is coming out. I boiled hot water and poured it through the pipe until the water flowed through both ends completely.
5. Re attach the pipe and screw the vent back on.
You have solved the problem!
I bought this refrigerator new in 1998 and it has been a great investment. This is the only problem I've ever had. I'm happy this was an easy fix.
It took me more time to find a fix on the internet than it did to actually fix it. So that's why I'm sharing the solution with you. I hope this is helpful!
Posted on May 15, 2009
  • 473 Answers
Will need a little more info on this one. Such as: No cool in both freezer and fridge section? Do you hear anything running, fans or compressor? If it is cold in freezer check to see if there is frost build up on back panel in freezer. Let me know so we can solve this problem.
Posted on Oct 05, 2007
  • lkscales
    lkscales Mar 13, 2013
    I am having this problem with my GE TFX20JR. I can hear fans running and cool air is coming out of the back instead of warm. Not freezing and barely cooling in fridge section. Any helpful hints or fixes would be great! Thanks!
Cant get to the other rows of coils.. Cleaned coils in front but can't reach the back even with a coil brush
Posted on Sep 20, 2008
Refergator not cooling freezer working fine
Posted on May 03, 2008
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
GE 19.7 TFX20JR not cooling or freezing
I think you fridge is low an gas, refill it
Mar 14, 2013 | GE Refrigerators
I have a GE Side-By-Side Refrigerator Model # TFX20JR . The refrigerator handle is loose and needs tightened and I can't find anything in my manual telling me how to do it. Your help would be greatly...
you must remove the inner panel to get to the handle screws on most ge 's . use red lock tight on threads to prevent it from doing it again . mm
Aug 09, 2010 | GE Refrigerators
GE TFX20JR
how is the freezer? if it is ok is the freezer back panel full of frost if so then you have a defrost problem and the ge is really good for the heating elements to go bad
Jun 26, 2009 | GE GSH22JFR Side by Side Refrigerator
Not cooling properly GE TFX20JR
Your refrigerator has a defrost thermostat inside the fresh food section behind the light cover and control panel. Need you to turn it clockwise slowly until the compressor stops. Leave it like that and after 30 minutes or less it does not restart you will need to replace the timer. The defrost timer is part number WR9X489
You should hear sounds from freezer with door open like sizzling or crackling. That would be the defrost working. If there is no defrost during this time. let me know so we can look into the defrost element and defrost thermostat as possible problems. Visit my site and enter the model or part number into search feature. That takes you to your model. Any questions or help from me, just let me know, Thanks, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Jun 18, 2009 | GE GSH22JFR Side by Side Refrigerator
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Frig mod#TFX26KPDA
More likely, the defrost system has failed.
There are three components: Defrost timer, a defrost heater, and a defrost bi-metal.
The timer can be located either in the food compartment, on the rear of the unit, or behind the kickplate. The heater and bi-metal are located behind the freezer rear wall (or freezer floor, depending on design). It's easiest to unplug the fridge overnight, with the freezer door open, to melt all the ice that has developed. PRIOR to doing all this, please ensure that there IS ice forming on the wall of floor of the freezer! Let me know. I hope this helps!
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
2,671 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
