Question about Kenmore Elite 45986 Front Load Washer
F06 code flashing -
Model HE4t - at any cycle, w/in 5 minutes of trying to fill w/water, stops working & flashes this code & beeps. Serviceman came out, said it was a loose wire, wouldn't show me how he "fixed" it & now it'll be 2 1/2 weeks before they can come out again. HELP!!
     Thought I'd share what I found out. Seems that the circuit board & the relay devices have had some trouble with shorting out. Not enough to require a recall, but enough to cause the consumer (us) grief. The repair people replaced all three electrical control devices  (don't ask me which ones) and HIGHLY recommended getting an appliance surge protector ASAP for the washer.
     He also gave me two pieces of advice. One, run 2-3 cups undiluted bleach placed in the laundry detergent compartment using the "whitest white" cycle & this cleans off the lint on the outside of the drum that can cause that mildew smell.
     Two, the front of the accompanying dryer has two lug nuts that are easy to remove once you get down to look. Take these off & clean the lint down there at least 1-2 times per year. This will increase efficiency & decrease stress on the dryer's engine.
Posted on Oct 17, 2007
  • 530 Answers
Does it keep trying to lock the door? does it make a ticking noise? if so you need a new central electric board. does it also give an f11 error code? these machines are notorious for this problem. It's caused by a loose solder connection from the factory that is why when they wiggle the wires it can fix itself until you try to use it again.
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
HE4t Washer
"F06" is a Motor Speed error. The following link explains how to troubleshoot and some common causes:
The first step to troublehsooting should be to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches with the unit. If the error code reappears following a computer reset, follow the advice given in the link I provided.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T Elite F06 problems
Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite he3t model 11045972404
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE4t cycle time blinking but nothing happening
remove lower panel reach up to lock area and pull down on tab to release door remove as much water as possible go back to bottom and turn pump clean out to left HAVE PLENTY OF TOWELS HANDY..clean pump trap out and reinstall
Nov 09, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
"FL' (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
208 people viewed this question
Sal De
 Brian Main
Brian Main
