Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher & Paykel Dishwasher
Error code "F3" what does it mean?
  • Anonymous Mar 14, 2014
    code error 50 whats the problem
    Scholar:
  • 146 Answers
If the machine has stopped and still has water in it, the drain pump is jammed. The pump is situated under the machine on the right hand side and can be accessed if you tilt the machine back against a wall. Try turning the motor fan by hand. Sometimes it will clear any foreign matter caught in the pump. If still jammed, remove pump by switching the machine off at the wall and pulling out the plug. Remove the wiring harness from the pump and turn it clockwise while releasing the white plastic clip which holds it in place and keeps it from turning on its own.
Posted on Nov 03, 2007
  • 77 Answers
F3 means your dishwasher water is too hot. Go to the link below and it will show you how to determine what is causing the error.
http://www.appliancerepairlesson.com/category/dishwasher-common-issues-repair/
Good luck
Posted on Mar 05, 2011
I have a fisher Paykel dishwasher and a e20 code came up does this mean it is blocked
Hi Vivianne
I found the definition of some error codes but I don't know if any of these will apply to your appliance:
Fisher Paykel Fault Codes
I hope this helps
May 29, 2016 | Fisher Dishwashers
F3 code and beeping noise
Not sure which model number dishwasher you have. But usually F3 error means a water temperature related fault. The water temperature is too high. Hopefully you are not using the hot water supply of your house. If so then ensure it is less than 80 deg C. If using normal mains supply (cold water) then it is likely the temperature sensor in dishwasher has failed. Not an easy job to fix as it is integrated into the water heater element at the base of the drawer for the DD603 drawer type dishwasher.
Mar 19, 2013 | Fisher and Paykel Dishwashers
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Jan 02, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
My dishwasher has f3 on the display and is beeping and none of the buttons on it are working what is wrong
if its a F3 error on a 2 draw fisher paykel, this means the temp sensor has detected that the water is hotter than 85 degrees celcius either the water coming into the machine is too hot, that or the heater plate has shorted possibly causing it to stay on for to long or the the temp sensor itself is faulty and giving false readings, if none of these things you will be looking at a control board
Nov 18, 2011 | Fisher and Paykel Dishwashers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher/ paykel dishwasher says F3
f3 water temp sensed at greater than 85 c or 185f check temp sensor or is element on all the time
Jun 29, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F3 error showing
F3 means the Dishwasher thinks it's water temperature in the tub is over 80oC. So when the unit stops see how hot the water is. The unit has a temp sensor which is part of the element which maybe faulty, the element maybe faulty or the Motor controller module is faulty. I'd try the Motor Controller module first as replacing the element can be a tricky job if you haven't done one before. If you have a double dishdrawer you can swap over the Motor Controller modules (main computers in the front of each drawer) as the top and bottom are the same part, inturn you will prove 100% if this is the fault or not without buying a new controller. Cheers
May 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
May 25, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
What is F4 error on fisher paykel dishwasher?
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Washing Machines Logo
901 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
