JVC TU-DB1 my JVC TU-DB1 freeview box has stopped working, it is only 13 months old there's power to the box but it won't try to tune in or light up
I Had this problem and found it was the power supply that had packed in so I replaced the supply with a Maplin LO6BR its the same switched mode 1.5amp type as JVC use
Posted on Sep 28, 2008
My Logik freeview box has will not tune some channels - most are fine. What can be done to fix this?
Usually that is caused by poor signal strength or a faulty tuner inside the receiver. Replacement boxes are only £18 upwards.
Nov 23, 2014 | Televison & Video
I have a Sharp TU-T2 freeview HD set top tuner. I inadvertently set the HD output to 1080p but my TV only accepts 1080i. An error message "out of range" appears whenever I switch on the set top...
Here is the correct solution from the user manual:
Hold the HDMI button on the remote control for 5 seconds to reset the output to 1080i
Worked for me.
Aug 13, 2011 | Sharp Televison & Video
Hi. I have the sharp tu-tv 322h which I bought from someone else. Its been sat in its box for a year unused and so when i switched it on and set it up i could only get one or two channels. The others were...
You should be able to get all the standard freeview channels without bothering with TopUP TV.
Follow the Instructions on Page 24 of the Manual at the link below.
http://www.tradenet.sharp.co.uk/files/Consumer_Electronics/DTR/TUTV322H/TUTV322H279.pdf
If this doesn't tune all the Stanadard Freeview Channels then you're not getting a strong enough signal for this unit so it won't be able to upgrade the TopUP TV side of it.
Jul 14, 2011 | Sharp TUTV322H
Total Control 4 wont work my freeview box
im looking for sagem freeview code on total control.
thank you
May 17, 2009 | Televison & Video
Unable to tune in and get picture/chanels
try to reset ur tv to factory setting.....should be in ur instruction booklet...when done try to set to automatic channel search and it should find Chanel for ur area
Mar 14, 2009 | Televison & Video
JVC TU-DB1SK : Unable to setup basic freeview
1050 1071 1199 1259 1280 1315
Press and hold TV until the LCD blinks then try each code and in between press standby, when the TV turns off that will be the right code. May work for you, if not post back
kind regards
Nov 29, 2008 | Televison & Video
Freeview box and dvd is not working
Have you checked the fuse in the plug for the dvd player?
Feb 18, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
106 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
