Question about Hitachi 50UX57B 50" Rear Projection Television
Ptcture I can see nay picture. On screen I am Getting Vertical line that curv on both side. I try by my self took folloing step I open front penal and turn some screw but Ican get picture
  • ramesh110 Oct 04, 2007
    I have open front penal and I turned some screw on the penal then I lost the picture and come out some line.
  • 979 Answers
Sounds to me like you might be in "test"mode. You'll have to find the correct button to press to get you back in the other function. If this fails, you'll need a tech visit...accordianman
Posted on Feb 18, 2008
Anything to do for vertical lines on screen?
most likely a damaged sensor. How about the pictures? Do they show these lines on them too?
Oct 23, 2015 | Canon PowerShot ELPH 340 HS Digital Camera...
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
Vertical lines on laptop screen
There are only two issues here, one it could be the data cable on the left side of the screen has come loose from the socket on the LCD.....most likely though is your starting to have a cascading screen failure and will need to replace the LCD panel.
Jan 05, 2010 | Dell Inspiron 9200 Notebook
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Projection TV keeps shutting off
Good Day, checho3435;
Try this to help to narrow it down:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Day, big IRISH. back.gif
Jul 30, 2008 | Mitsubishi WS-55807 TV
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
65 INCH PROJECTION SCREEN IS SUPER BRIGHT
super bright is due to failure in video section. 1 video supply might be absent. 2 g2 voltage mighi be high gue to some part defective at ground side. 3 chroma or jungle ic not getting supply or defective. 4 luminance section defective. BUT AS you are also saying that it came once after hitting on top so there is also possibility of loose contact also. good luck.
Sep 18, 2007 | Mitsubishi WS-65819 TV
Screen Size is Too Big
There should be a vertical height adjustment control potentiometer near the vertical output IC on the right side of the PC board near the front section of the TV that can be adjusted to shrink the picture vertically. Be careful not to short anything out or getting yourself shocked in the process if you decide to try to adjust it yourself. Good luck. This chassis has also been known to have bad solder connections in that area also, so don't man-handle the printed circuit board roughly.
May 23, 2007 | Zenith D32D51 32" TV
Hitachi 50UX57B 50" Rear Projection Television Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
