Question about LG LB8000ER Air Conditioner
Unit filled with water -hard to drain
I have the LG 12000 BTU Air conditioner, and its been working great. Recently, I noticed that when on, it would hum like the fan wanted to turn but couldnt. Being off a while fixed the problem, but it would sieze again. I live in a humid state, so when I read that you might need to drain the unit, I figured my problem is solved. However, I live on the second story of a building - and getting to that drainage pipe in the back is going to be a real pain. Is there any way I can do this without killing myself? Thanks for your help in advance. -Kaerbear
  • LG Master
  • 909 Answers
Possibly its a capacitor thats faulty and not the drainage. still, the unit will have to be removed from its casset (case) to be repaired.
Posted on Oct 23, 2007
How much water do I need for the air conditioner
I've never seen an air condition device that needs to add water to work. Actually they RELEASE condensation water and you need to collect this water or drain it through a tube
Jul 20, 2015 | Sunpentown Spt Tn-12e Technitrend...
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
I bought lg portable 9000 btu air air conditione two days ago. The unit fills up with water every few hours and the drain plug does not work. I have to move I it outside and tip it over to get the water to...
Hey there. I bought the same AC unit and was experiencing the same issue. Wouldn't drain, etc...
I'm happy/embarrassed to mention that there is a rubber grommet inside the drain plug that I did not see before. It looks like it's part of the plastic drain, but it's a rubber cap. So when you unscrew the plastic cap, there is another rubber plug you have to pull out.
Doh!
Hope this helps.
-C
Jul 05, 2012 | LG LP0910WNR Air Conditioner
Water
This ac unit will have to be taken apart and clean out the drain holes in the bottom of the case.Use a water hose to clean and wash it out,also remove any large objects by hand,of course you will have to remove the unit from the window to do this.
Apr 16, 2012 | DeLonghi PAC C120 12000 BTU Portable Air...
Where does the water drain out of the unit on the frigidaire 10000-12000 btu and the 22000-285000 btu units?
The unit should be angled back to the outside. The water will run thru a tube from the indoor coil to the outdoor coil, then most fan blades have a slinger on them that picks up the water and throws it on the out door coil, which makes it more efficient but after time the water and dust will pile up on the coil and require cleaning at some point. If you clean the coil you can extend the life of the unit quite a bit. So you may not get any water to drip outside.
Jul 02, 2011 | Frigidaire Wall Room Air Conditioner...
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
Lg 12000 btu air conditioner inverter is not working and the led 6 times.thanks
This alarm state is a CH 06 alarm.
Indication for the Indoor unit pipe temperature sensor (thermister) not plugged in or out of calibration.
This alarm will also occur when the unit gas charge is to low and the indoor unit temperature reached a temperature of -5°C for longer that 30 sec. It will switch the machine off.
Mar 21, 2010 | LG Electronic Window Air Conditioner
New unit has loud noise & doesn't drain. Too late to return!
drain line kinked? trying to diagnose a noise problem over the inter net really hard . could be compressor
Jun 17, 2009 | Danby Portable Air Conditioner
LG LB8000ER Air Conditioner Logo
67 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
