Unit works fine when running on battery power. When running on 120v it makes a loud buzzing noise and the compressor does not kick on.
SOURCE: Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
SOURCE: Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
SOURCE: the freezer is defrosting and the refrigerator is
Probably not. The compressors are very sturdy and long lasting. The compressor is controlled by a start relay, and is protected by a thermal overload. It sounds like your start relay is bad, which would explain the buzzing sound. It takes a certain amount of time to cool down, and then tries to start again. The start capacitor and start relay should be replaced.
