Question about Nikon N75 35mm SLR Camera
Nikon n75 problem loading film
When I try to load a new roll of film into the camera, instead of loading the film, the camera will rewind it back into the film cannister. It used to be an occasional problem, but it's now rewound the last six rolls of film I've tried to load. When I close the door, I can hear the gears going, but never the click and the numbers on the screen don't start advancing. Then the ERR message pops up and when I open the door the film has been rewound back into the case. I've tried taking out the batteries to reset. Any help would be greatly appreciated!
  • Anonymous Dec 08, 2007
    I have the same problem. Before this started it would periodically lock up so that I couldn't do anything. Now this is all it will do.
  • PaulMarquis Dec 16, 2007
    I am having the same problem and the mirror is locked up also any clues?
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
GOOD LUCK.
andy
amasseur at gmail dot com
Posted on Feb 09, 2008
This is a known problem with this camera (and not the only one..). The fix is easier but ammaseur was close enough.. The fix is to manually force a film rewind by pressing at the same time the two rewind buttons (marked) as described in the manual. Then it should work fine until it happens again & you'll have to repeat. Hope this helps, otherwise an ok camera for the price.
Posted on Feb 22, 2008
Film not going through camera
E indicates empty.
try resetting the camera. Pus both the rewind buttons (plus/minus button by release button and bracket button on side of mirror box). Push them at the same time. Let the camera run until it stops (just a few seconds). This resets the camera. Then try loading the film again. Make sure the leading edge of the film isn't bent and is the edge is within the red rectangle under the take up spool. It should then load the film. Note: the N75 pulls all the film out of the cassette and then rewinds it back I one shot at a time until you reach '0'.
Aug 12, 2014 | Nikon N75 35mm SLR Camera
The new roll of film winds into the right spool upon closing back cover // brand new batteries displays 1/2 and ERR appears on led panel
Is the ERR blinking, and is there an additional blinking E on the display? If so, the film is not loaded properly.
The film is supposed to advance all the way to the take-up spool upon loading. The camera then "rewinds" one frame at a time as you take pictures. This way the camera knows exactly how many shots are left on the roll. Also, if the back is accidentally opened, the shots already taken are already in the can and won't be ruined.
If you need a manual, you may download a copy here.
Try cleaning the battery contacts and see whether the battery reads full with no film in the camera.
If problems persists, feel free to reply to this post and give any additional details.
Mar 04, 2012 | Nikon N75 35mm SLR Camera
Rewind stuck on reverse
Hi Luce n Steve, To quote JC at Photo.Net: "sometimes the rewind function "gets stuck" if the camera thinks a previous rewind did not complete successfully. The solution is to reset it by forcing a rewind operation. Just press the two rewind buttons simultaneously: on the left side of the lens and just behind the shutter release. (They are marked and the manual explains how to force a rewind.) I did exactly this, and my next roll of film loaded without problems." Hope that help you folks.
Aug 22, 2010 | Nikon N75 35mm SLR Camera
Hi: I have a nikon n75 I have film in the camera but looking for the rewind button. Not able to locate my manual. First time doing this.
There is no rewind. When the camera loads the film, it pulls it out all the way. Each time it takes a shot, it rewinds the frame back into the can. At the end of the roll the leader is wound back into the can. As soon as you hear the motor stop, you can just open it and take out the film.
Oct 05, 2009 | Nikon N75 35mm SLR Camera
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Aug 08, 2009 | Nikon F60 35mm SLR Camera
New film is being rewound and the viewfinder is blank
The rewind switch is stuck. You will need to replace it or remove & clean it. replacing it is easier to do than tearing apart for they break so easily
May 11, 2009 | Nikon N75 35mm SLR Camera
There's half a roll of exposed film that we want to preserve and we're getting a message "err."  We need the film to rewind back into the canister.
I suspect you are getting that message as the aperture on the lens is not set to its largest number (ie 22). The camera needs that so that it can control the aperture opening in the exposure modes. Try setting that to the biggest number, then power the camera back on and hopefully you'll be back in business.
Here's a link to the N75 / F75 user guide:
ftp://ZUAB14RT:F3NET50W@ftp.nikon-euro.com/Manuals/M1GTMV8H/F75_En_02.pdf
Dec 07, 2008 | Nikon N75 35mm SLR Camera
Nikon N75 - error message, nothing working.
You have to reset the rewind counter by pushing the two buttons simultaneously - one on the side of the lens mount, the other by the release button - red, cassette symbols. This tells the camera there's no film in it.
Nov 30, 2008 | Nikon N75 35mm SLR Camera
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Nikon N75 35mm SLR Camera Logo
447 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
