Question about SanDisk Sansa e250 MP3 Player
Sound when i plug into the heasd phone jack the left speaker goes out occasionally and i am not able to hear anything i have tryed diffrent headphones and it still does the same thing what is wrong?
  • 8,596 Answers
Hardware issue - must repalce player
Posted on May 26, 2008
SOURCE:
No sound at all when headphones are plugged in
Hi, I apologize in advance for not offering a solution. Have just trolled through the handbook (on-line) for anything that might offer a clue. It takes both high and low impedance units so that's cool. They say to use the phones to assist with speaker issues and there's nothing to suggest that any of the settings affect them. Depending on the impedance the volume levels can change a fair bit so I guess you've cranked it up to check. The fact that they turn off the speakers doesn't add a lot, it can often be a simple mechanical switch in the socket when the plug is inserted. Does the 'speaker off' indicator come on when you plug them in. The only other things I'd suggest is both try another set of phones regardless and the other is reset all the sound settings to factory and see if that has any affect. Else you likely have an issue with the phone interface circuitry.
Jan 05, 2012 | Sony STR-DE575 Receiver
I cannot hear while making calls. The volume switch does not work either. When I make a call the other person can hear me but I cannot hear anything. The system sounds and ringer volume are turned up....
When making calls, try putting it on speaker phone.
This problem is widespread, and it is due to a problem where the phone does not recognize that the headphone jack has been unplugged. This means that the phone will send data to the headphone jack, and not to the speaker anymore. You can try to 'unstick' it by inserting and removing a jack until it recognizes it, or repeatedly blowing into the phone's headphone port. Both of these solutions have worked for me, but they take quite a bit of effort, so I have just gotten into the habit of using speakerphone. For me it still works, event when the phone is in headphone mode.
May 01, 2011 | Palm Pre Cell Phone
When i plug my headphne and it only hear the left speaker intstead of the right i only hear one side only instead of both sides and when i try to play through my stereo bluetooth and its said you have to...
Sounds like your headphone's port on your phone is the cause.Try connect,disconnect and then reconnect the headphones for a few times to clear it up.
Jul 28, 2010 | Cell Phones
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Hello. My Head phone jack is not working. I have a Sony Vaio Laptop and the speakers on it are working fine. When I put the head phones in it I don't hear a thing. I've up dated the drivers and it seems to...
Sounds like your headphones may need to be replaced. I'm assuming they don't work with anything else.
Try cleaning the plug with a lightly dampened paper towel and use a can of compressed air to clean out the jack on the laptop. If that doesn't work, try another set of headphones.
Nov 25, 2009 | Sony VAIO VGN-NR310E/S Laptop
No sound
try rolling back the driver,or go online to update it...."sound driver"maybe it is the jack plug outlet.....as a quick check,turn the system sound nearly right down,and quickly plug in your headphones into the jack outlet,if you hear anything through the head phones"not wearing them"then its the lead and jack on your speakers..
Aug 02, 2009 | Logitech X-230 Computer Speakers
No sound from creative t3030 2.1 speakers
the circuit board and amplifacation supply inside the sub are blow or shorted out.thus preventing any sound. the head phone jack works only because it is a bypass feature supported by the actual computer not the surround sound unit
Jul 23, 2009 | GE Ultrasonic 2.1 Subwoofer Computer...
Only hearing sound out of left side of headphones
i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
Dec 22, 2008 | Creative Labs Sound Blaster Live! 5.1...
Headphone Speaker Jack Needs Replacement
That honestly sounds more like a headphone wire problem than anything else. If you have another headset, headphones or speaker system that you can hook up, I would test it on those to try to rule that out as a problem.
If that isnt it, I can try to find the disassembly instructions for your laptop. (Unless your warranty is still good, in which case I would tell you to send it in and get it fixed professionally.)
May 16, 2008 | HP Pavilion ze4125 Notebook
SanDisk Sansa e250 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
