Question about Dryers
Intermittant heat for drier
Upright washer/dryer combo (1 piece unit)dryer spins ok,but no heat,or there will be heat and than after a load,there is no more heat,I tested the temp selector switch,ok,I also just tried dryer and had door open with door switch pushed in and dryer works for around a minute,than I herd a click at the rear area and than there was no more heat, I had the rear bearing replaced about 6 months ago for dryer,unit is 10 years old
  • geterdoneguy Oct 03, 2007
    upright washer/dryer combo unit (1 piece) Kenmore {Sears 970-17802-20} as taken from drier door
    I forgot to mention it is electric
  • 209 Answers
Check for flow of air through the dryer arts as it sounds like the clicking is the thermal cut out activating, this prevents the dryer from overheating, the common cause for overheating is blockage (no air flow) or the fan that blows the air round the machine is not working, or not working properly, so check the fan see if its turning etc hope i have helped, if so please rate me
Posted on Oct 04, 2007
Washer only start when drier is on.
Hello Reinaldo Rivera - From what you have described the unit seems to either have a communication problem with the control, an issue with the wiring harness or a faulty door switch. Try resetting the unit by flipping the household circuit breaker or unplugging. Wait approximately two minutes and turn on the washer. Select a normal cycle and if issue continues then I suggest contacting a professional to move forward accurately.
Oct 11, 2012 | Frigidaire FEX831CS Top Load Stacked...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Belling integrated washer drier will tumble ok but there is no heat. Is this easy to fix?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 30, 2010 | Belling SGE12X Front Load Washer / Dryer
Separating a washer dryer combo
This is a one piece unit. It does not come apart. Use and appliance hand truck with straps to secure. You will need at least 2 people to get unit out, heavy. I used to deliver appliances.
Jul 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Estate Dryer takes too long to dry load
Since you say the vent is clear, Make sure that the lint filter is cleared before each load. Make sure the door shuts close and is reasonably sealed. If the dryer draws air past the door, it is not fully drawing heat from the element or burner. Also make sure the washer is doing it's job in the spin cycle. It takes much longer to dry fabrics that are still soppy wet. You might try resetting the washer in the spin cycle to further evacuate the water from the clothes before placing in the dryer. See if that makes a difference. Maybe the washer spin is just being lazy. If it's a top loader it may have a loose belt causing the problem.
Dec 16, 2008 | Estate Dryers
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Drier Motor
Disconnect the vent at the back of the dryer and dry a load unvented to make sure you don't have a clog in the vent line too the outside causing an air flow restriction, if still not drying check and make sure the blower wheel that circulates the heat inside the dryer isn't broken.
Jul 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
99 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
