I need to program a VA-405 universal remote to work with a emerson television.
1. Look up your TV's brand in the TV code listing that starts on page 12.
2. Circle the first 4-digit number displayed for your brand of TV.
3. Turn on your TV.
4. Press and hold the TV key.
5. While holding down the TV key, press the OK key.
6. Release both keys. The Device Keys will blink twice.
7. Enter the 4-digit TV code you circled. The TV key will blink
three times.
8. To test to see if this was the correct code, point the remote at your
TV and press Power. If the TV turns off, you have successfully
programmed your remote.
9. If the TV does not turn off, repeat all the steps using the next code in
the list.
10. For future reference, write down the code that worked, in case you
must reprogram your remote.
NOTE: If some of the keys on the remote do not operate your TV as you
would expect, then you can try the next code in the list for your brand of TV.
If none of the codes worked, try the following procedure. (As before, we will
use the example of a TV. For other devices, use the appropriate Device Key
instead of the TV key, in steps 2 and 3.)
1. Turn on your TV.
2. Press and hold the TV key.
3. While holding down the TV key, press the OK key.
4. Release both keys. The Device Keys will blink twice.
5. Press 9 - 2 - 2.
6. Point the remote at the TV.
7. Press .
8. Press . Every time you press , the remote sends out a new
power-off command to the TV. Keep pressing until the TV turns
off. (You can press to go back.)
9. When the TV turns off, you have found the right code. Press OK to
store this code.
There are over 200 TV and DVD codes. The most common codes
are tried first, but you may still need to press over 200 times to find the
right code. If you reach the end of the list of codes, the entire remote will
flash twice and return to normal operation. You can exit programming at any
time by pressing Exit.
