Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi WS-65809 Color Distortion
The top left and right corners of screen display a distorted coloration. Its fine at initial startup (powered on)then it comes and goes frequently. What could be the cause of this? I would appreciate any help or advice you can provide me. Thanks in advance, Elijah
    Genius:
  • 1,694 Answers
Bad connections on pins of STK IC's.Replace w/high quality new parts for reliability. Re-align as needed. .
Posted on Oct 04, 2007
SOURCE:
Mitsubishi 65611 has color distortion and bowing
the color convergeance is out of alignment. you need to have a STK chip replaced.
Mar 20, 2010 | Toshiba 50H81 50" Rear Projection...
Bottom left corner of my toshiba 65h83 is blurred with color distortion mainly magenta and green. Distortion Is a half moon shape with the open end facing the edge of the set. Total distortion takes up...
Have you tried the "Magic Focus" Button/Option in the Menu Setup Screen? If you have and it still is there, You Have a Burned out Color Tube. It is Cheaper to Throw it away and Buy a New one.
Good Luck..
May 12, 2009 | Toshiba 42H81 42" Rear Projection...
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
I think it what is called convergence
Maybe loose connection on the convergence board around the IC's or amps
Mar 22, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65809 65 in. Rear Projector
Bad solder connects on pins of STK convergence IC's.Replace IC's for reliability,then re-align if necessary.
Oct 04, 2007 | Mitsubishi WS-65809 65" Rear Projection...
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
