Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
No screen no post
Everything brand new green light on all fans working ethernet shows lights dvd player not opening ram in yellows slots matched pair 2gb corsair 800 ddr2 new hiper psu 580w amd x2 6000 cpu all in one wonder x16 graphics card?
  • 4 more comments
  • Anonymous Nov 17, 2007
    Exactly the same problem, AMD 4400+, Kingston RAM 533mhz ddr2 as listed in the compatability section of manual, Nvidia 7600GTS graphics card, dual seagate SATA drives, dvd.
    Power on, ethernet lights up, no beeps, dvd will not open. Tried different memory slots, ide slots, power supplies. CPU is fine as its come come out of my Gigabyte GA-M55Plus board, RAM fine. Just will not post. Going to RMA the piece of S**t. Seems this is a very common problem with this board.
  • Anonymous Dec 13, 2007
    Disk Boot Error, please insert System disk and retry
  • besouro Jan 05, 2008
    All the lights go up, the fans too. Simply the system doesn't boot, doesnt even get to the post screen. I tried disconnecting the drives, i tried getting the RAM out, putting out the cmos battery. nothing solves it.
  • ark4peace Feb 17, 2008
    Same thing, only my CPU fan isn't even running - lights on board, nothing else running. I took it back to the shop where I got it. It's clearly not the PSU, since it runs everything NOT powered through the mobo fine, and a working PSU doesn't make CPU fan run either. It really can't be any of the other components (RAM, VGA, CPU, drives, etc.) since those things won't prevent POSTing. They might cause a post fail, but it will at least TRY, and give off a couple of beeps... but not *nothing*. I strongly suspect that if you run too much wattage through the board (read: you can't actually run as much wattage as the mobo manual claims you can) it dies. Anyways, I got mine RMA'd, and I'm waiting on a new one.
  • wsdavis Apr 08, 2008
    ASUS M2N SLI with AMD A64 x2 5400+ Processor will not post. PSU test is OK. Is this MB pone to have problems? It's looking like an RMA????
  • Anonymous Apr 14, 2008
    Same problem - almost. Fans run, disks spin up, DVD okay, even some lights on mobo, but no beeps and no POST. Swapped CPU (happened to have spare) - no difference ! As others here also swapped memory, changed drives etc. Only thing is, it *had* been working fine for few weeks, then one day wouldn't boot.
  • 23 Answers
Can u give me more details
Posted on Oct 06, 2007
6ya staff
SOURCE:
Do you need the red yellow white blue and green to have it show on the power its on but it wont show up on the t.v. so if you know whats rong on it holler at me
You need tyo select the input on your tv that matches how you have the dvd player hooked up if you are using hdmi select hdmi, if you are using the red yellow green blue and white cords these are called component video cables so look for something along those lines on your input selection screen
Apr 02, 2011 | Cyberhome CH-DVD 300 DVD Player
My CH DVD player is about 10 years old. I can't turn the unit on either with the remote or power button. The indicator light is neither red nor green but yellow. None of the unit's buttons work and I...
Unscrew the casing and take it out from there. By the sounds of it your dvd has bitten the dust so it wont matter much about damaging it anymore than it is already
Jan 26, 2010 | Cyberhome CH-DVD 300 DVD Player
Compaq evo 510 Won't power up.
Could be bad RAM modules. Try swapping out the RAM in the system with new RAM. Install one stick, in one slot. If it boots, that stick and slot are good. Try the stick in each slot to make sure all slots are ok.
Feb 20, 2009 | Compaq Evo D510 Minitower (Open Box)...
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Disk drive won't open & lights flash
samsung told me it was defective and to send it in at my own expense. Throw it out and dont buy samsung
Jan 07, 2009 | Samsung DVD-P241 DVD Player
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
GX260 DOESNT BOOT
Potential Problems : 1. RAM loose in the slot. Take it out, clean the contacts and reinstall 2. CMOS Battery ( Most probably Battery number is CR 2032 ), just replace it by a new one. 3. Faulty SMPS : Change / get it repaired. Good Luck, Rajesh
Aug 18, 2007 | Dell OptiPlex GX260 PC Desktop
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
185 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
