TV We have perfect picture but no sound, when changing channel you get a sharp noise and thats it
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
We have perfect picture but no sound when changing channel you get a sharp noise and thats it 1 reset once 2 ptoblem in transmission 3 as noise is there so your audio section is alright. the problem is sound signal in not reaching to audio section or print break in that line or some one has mistunned sound if section coil. hope this will help.
Posted on Oct 06, 2007
SOURCE:
The TV has perfect picture but no sound how do I get the sound back on
Are you by chance on the SAP audio channel instead of the main channel? You should be able to go into the menu and look at the audio settings. If you are on SAP change it back to main. Some stations do not have audio on the SAP channel.
Jan 20, 2017 | Televison & Video
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Trying to connect Sharp VCA310X VCR to TEAC TV CTM5140; am only getting blue screen with audio; no picture! Have tried every possible combo with the AV cables (red, white, yellow).
I would suggest trying to change the channel, either on the tv or the vcr. Sometimes, if the channel is one off, you will get sound but not a picture. On the back of the vcr, there SHOULD be a switch to change it to either channel 3 or channel 4. You must match this up with the channel your tv is set for. I hope this helps, but if not, I hope you can get it figured out soon. Good luck! Der Strom
Apr 13, 2010 | Sharp Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Jun 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Certain channels on my tv have no sound and others broadcast randomly in spanish...while the same channels on a different tv in the same house are perfectly normal. How can I clear anything that might have...
i just fixed mine on my jvc tv by going to the settings and changing the 'noise muting' secion to off and the 'mts' setting to stereo..
dont know which one changed it but now i have sound on all channels. you can change the language settings in the menu too
Apr 29, 2009 | Televison & Video
MY SHARP 20 INCH COLOR TV GIVING NOISE IN SOUND?
your A.F.T. COIL ADJ AND SOLVE THIS PROBLEM
Jan 16, 2009 | Televison & Video
Distorted sound, great picture on a Sharp Aquos 42" LCD
i belive that it is the brodcasts problem there is nothing wrong with your tv
Jan 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, only sharp, squeaky noise
I'm having the same exact problem with mine! I'm looking for a solution also. I opened up the back of the TV and blew out the dust. Then I checked all connections. I put it back together and plugged it in. Now it doesn't make the high-pitched squeeking sound, but I still don't get a picture. My guess is the picture bulb is burnt out. I'm trying to find one online and am planning to fix it myself - wish me luck!
Aug 15, 2006 | Panasonic CT-36D32 36" TV
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Ekse
