Question about Refrigerators
Whirlpool ref/freezer ED22LF
Everything works and cools with icemaker in off position,as soon as the icemaker is engaged it shorts out and the fan and compressor stop.Is this most likely the icemaker/timer unit or motor? Thanks, George
  • 447 Answers
Wow that is weird ive heard of such a thingd id try a new imaker first if i was on the job. Please rate my solutuion as solved if you appreciate my expert advise>>>>>>>
Posted on Oct 03, 2007
I have a whirlpool ref/freezer the ice dispenser won't work. makes ice and water dispenser is ok. sv
Your model appears to be quite simple electrically. It does not have a major circuit board it's very possible that the pressure switch, wire connection at the dispenser, hinge or the interlock freezer lightswitch is bad on your model. Do you have a multi-meter/OHM meter? John T. Appliance 911 Appliance 911 Sea Breeze
Here is a manual that is very close to your model http://appliance911seabreeze.com/KSBS20QEWH0%20_ED20DFXEB00_Serviice_Manual.pdf
May 09, 2014 | Whirlpool EL02CCXP 19" Cold Pals Compact...
Whirlpool ref fan problem model no wbtxnwfwto1
did you check the fan motor with a meter to see if it's good?also the model number you sent doesn't show up,is the freezer cold?if the fan motor is checking good with meter you could have a bad or loose wire.send back info and we'll see what we can do.
Jul 29, 2012 | Refrigerators
All the options in ( cool , auto cool, high cool) are on ( lights on) and making noice . We would like to know the problem.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 20, 2011 | Refrigerators
Refrigerator not cooling. freezer is working correctly.
NOTE: This
Leo Ponder
imufo2
Sep 19, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
My ice maker doesn't seem to be working... I pulled the fridge out to check that the lines were connected (and they are) & that there are no kinks in the lines ---- everything seems fine, but the...
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Sep 10, 2011 | Amana ARB2217CSR Bottom Freezer...
I have an ED2FHG side by side Whirlpool Fridge. The ice container was full and the lever was in the down position when I opened the freezer. Then I noticed that my freezer was dripping water from the ice...
NOTE: This
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Aug 19, 2011 | Whirlpool (ED2FHGXSQ) Side by Side...
Freezer not freezing door items and the frig part is not cooling! Less than a year old
NOTE: This
I'm
Leo Ponder
imufo2
Aug 15, 2011 | Whirlpool Refrigerators
Whirlpool refrigerator not making ice
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jun 05, 2011 | Whirlpool Refrigerators
Have a Whirlpool refrigerator that has stopped
replace the electronics on the compressor --if you would like more tech diagnosis let me know
Aug 10, 2009 | Refrigerators
Whirlpool Refrigerator - Model# ED22LF
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
Jun 28, 2008 | Whirlpool EL02CCXP 19" Cold Pals Compact...
Refrigerators Logo
156 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
