SOURCE: Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
SOURCE: Maytag Ensignia Oversize Cap Plus Washer stopped working in mid cycle
Check the water level control, it could be stuck or faulty.
SOURCE: Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
SOURCE: maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
