Question about Goodman CLQ36AR49 Air Conditioner
What's wrong with it?
OK.....my ac has quit cooling--my husband changed out some sort of switch with "points" on it --at first the fan outside was not running and after he changed the switch out it proceeded to work correctly. The switch looked as if it had burned a little bit--part of it crumbled apart. Two days later it has quit again --it is blowing warmish air out and the fan outside in the unit is working but it is blowing cool air instead of warm. Is there any way my husband can fix this himself and can how he fix it and what is wrong with it???
  • 447 Answers
There are lots of things that could be wrong since he just changed the contactor a wire may have burned...Very common..Make sure all wires feel snug onto terminals. The compressor run capacitor may also be bad it looks like a batter with 2 or 3 terminals if it looks bulged on the top where the wires are than its bad ...if it looks flat you would have to have a meter that checks capacitors to test it. Those are all the easy items to correct..Call for service if all cks ok Please rate my solutuion as solved if you appreciate my expert advise>>>>>>>
Posted on Oct 03, 2007
SOURCE:
Why are my cooling fans for radiator running constantly?
The cooling fans are supposed to run any time the a/c is on in order to keep air flowing across the condenser. Your a/c will not work properly at idle if they quit.
Jul 27, 2015 | 2010 Ford Escape
On my 2006 ac works good when engine is cool, in stop & go traffic it blows hot air & head pressure gets high in ac, car temp is ok what's wrong
How do you know head pressure is high? Do you have an auxiliary electric cooling fan that is not coming on in this situation? It should be in front of the AC condensing coil. There may be a switch tied to the system that is bad. This switch is sometimes activated by the pressure in the high-pressure line to the condenser coil. If there is not enough freon (134a) the pressure will not be high enough to activate the cooling fan switch. I recently added one can to my system and it made the fan run whereas it did not before adding the freon.
Jul 05, 2015 | AC Cars & Trucks
Bought a Frigidaire FTD080600948 Central Ac & heat pump 13 months ago. Compressor fan outside quit working yesterday. Compressor runs but can not cool because the fan won't cool the coils. anything...
yes there is a silver cylinder lookin object thats called a compasitor which goes to the fan motor change that out to see if thats the problem if not your fan motor is the problem
Jun 04, 2010 | Heating & Cooling
Cooling fans and AC on 2000 Jetta 2.0 litre GLS - not working!
worked on one of these last week as well done the door locks and gearchange.Cant remember but look around the rad area for a reostat pack ,also check the earth on the fans and for a feed as that will give you a clue what could be wrong ,but the fan should come on with the AC so something is amiss .My favourite is to run a feed from the battery and then try pushing it behind the positive ,and then do the same with the earth,Cant live without the AC here in alicante spain ,its still about 28 outside now and its 22.11 ,try it out then get back to me if you cant sort it because i have to go now to pick er indoors up from work
Aug 17, 2009 | 2000 Volkswagen Jetta TDI
A/C just quit working. No cold air.
there are few problem with the A/C cooling system better check for A/C unit fuse weather it is blown or in good condition, check for the proper working of A/C condencer unit fan motor assembly for proper working, check for weather their is no lick of gas any where in the entire A/C unit complete system or more problem better consult or take the vehicle to nearest Hyundai authorised workshop or better take it to a well knon or experiencied person who had done this sort of problematic work.
Jul 22, 2009 | 2003 Hyundai Santa Fe
The compressor on my home ac willnot kick on
The fan and the compressor both run off of the same circuit. Have your husband remove the cover on the condenser coils and check for power at the leads that go to the compressor off of the latching relay. If there is power there, then he needs to check the start capacitor or possibly the thermal overload switch (mounted on side of compressor)
Jul 11, 2009 | Heating & Cooling
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
2006 corolla electric cooling fan not working
check the ac switch, evaporator sensor.
Apr 20, 2009 | 2000 Toyota Corolla
High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Oct 26, 2008 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
128 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
