Question about Nintendo DS Lite Console
Lights on bottom screen don't light
While playing my son's DS lite the touch (bottom) screen seemed to go dull as if i had dimmed the light. i tried using the brightness feature but that is not the problem. it seems like there may be several bulbs or LED's iluminating the display and more than half these have stopped working. The light on the top screen is fine. Can anyone help? is this fixable?
I dont think it is a problem i think it just does it to save energy
Posted on Oct 09, 2007
SOURCE:
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
Nintendo DS lite dim lower screen
under the battery cover there are 2 potantiometer which looks like screw , play with them carefully til you get clear picture , if they dont wortk you will need to replace your screen
Apr 27, 2010 | Nintendo DS Lite
Bottom screen problem
that is exactly what it is there are not many things YOU can do but you can try calling Microsoft, bricking happens when you drop your ds or hit the touch screen to hard or in your case magnets probably rubbed against it
May 05, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Touch screen dimming
Defective LCD Screen under the touchscreen. Replace it.
Nov 20, 2008 | Nintendo DS Lite Console
Nintendo ds lite screens dull
in the bottom left hand corner of the ds screen, there is a icon that looks like the sun. touch it and it will light up.
May 07, 2008 | Nintendo DS Lite Console
Nintendo ds lite bottom screen
you should go return for anothert it will probably get worse
Mar 12, 2008 | Nintendo DS Lite Console
DS LITE BOTTOM SCREEN IS WHITE WITH BLUE&GRAY LINES
u need a new screen in the bottom, try to get a nintendo brand screen instead of an aftermarket.
Dec 15, 2007 | Nintendo DS Lite Console
Dim bottom screen on DS Lite
There should be either a button or a setting to adjust the lighting, try doing that.
Dec 01, 2007 | Nintendo DS Lite Console
Bottom Screen doesn't work but lights up
cable problem most likely usually cheaper to replace.
Oct 06, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
182 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
