we replaced a new drum because it said that it needed a new one. So we did and it still says to replace the drum even thogh we replaced it with a new one. what can we do ?
Is the new one a compatible or a sharpe original if compat fit a new original as this maybe the cause if an original check and clean all the contacts or you just might simply have a faulty drum unit.
I just added the new ink cartridge and the light for the addd new drum cartridge won't go off. what...
(More)
I just added the new ink cartridge and the light for the addd new drum cartridge won't go off. what do i do?
guys have you ever seen a Sharp AL 1651 with a small case letter 'd' in the display? this happens...
(More)
guys have you ever seen a Sharp AL 1651 with a small case letter 'd' in the display? this happens when the machine is turned on in the morning....several on/off cycles will clear it. When it has the 'd' it is locked up...can't get in the service mode or anything...very strange. Any ideas?
Scanner clicks, looks like belts are slipping. It says to refer to user guide but there is no such...
(More)
Scanner clicks, looks like belts are slipping. It says to refer to user guide but there is no such error code in the book.
Hi, Can you tell me what the procedure is to reset the Drum count on a Sharp AL-1651CS. I got the...
(More)
Hi, Can you tell me what the procedure is to reset the Drum count on a Sharp AL-1651CS. I got the dummy info coming up saying its close to needing a new Drum... I reset this before on another sharp copier, but can't seem to find my notes on procedure.
