Question about Frigidaire GLEFM385D Electric Kitchen Range
LOC for oven door is unable to unloc
The LOC for oven door has been on for 2 days and I can't get it to "UNLOC" I have read the manual and tried all the suggested solutions and all are in vain... Please help Marj
  • 30 more comments
  • NewtonJohn Nov 05, 2007
    I can't get the loc to unloc, the over controls are blocked from being operative. Help!
  • TomDoc Nov 07, 2007
    Same problem as above. Any idea what it costs to replace the motor and/or fix this issue?
  • marombatube Nov 07, 2007
    i do have the same problem and show this mensage on the panel loc 5ab what sure i do that way the oven and panel works
  • LLEH Nov 13, 2007
    I used the self cleaning mode and now my over wont unlock. Help!
  • Anonymous Nov 18, 2007
    After using the clean button the control panel "stop time control" started to beep repeatedly during the cooling down process. I unplugged the range and reset the time. The oven door has been locked for the past two days. I have tried to cancel without success, and I have tried to find a program reset without success. We do not have a product user manual. OUR MODEL NUMBER IS ACTUALLY MR5750ADW, but this is the closest one I can find.
    Thanks
    Charlie
  • Anonymous Nov 22, 2007
    error 154
    I had the same problem, cleaned my oven now the panel is black. i tried to reset my circuit breaker but that didn't fix the problem. Of course this happend on Thanksgiving. Has anyone found a solution to unlock the door and getting the oven to work? I need this ASAP.
  • limomof4 Nov 26, 2007
    I am so frustrated with this range. This problem happened last year. My husband actually broke the door open and then ordered the parts online to replace them.
    Beware -- I came home one night to find the house filled with smoke. The oven was off, but the broiler went on (by itself) fullblast like it was in self cleaning mode. And since the oven was off, the only way to shut it was by the circuit breaker, then unplug it. Every time we tried to plug it in again, the broiler goes on full blast without the oven being on.
    The range is now at the curb. And Sears was not sympathetic to the fact that my house could have burned down. I just ordered a Maytag.
  • ericboone Nov 28, 2007
    connection oven door is locked. unable to unlock
  • char46 Dec 01, 2007
    the handle on the oven door won't move and I can't get the oven door to open.
  • vmf1 Dec 02, 2007
    loc came activated. not even sure how. now loc stays on and oven controls are blocked. cleaning is blocked but door stil opens please help...
  • otty Dec 08, 2007
    the oven door is locked and won't open. The lock button keeps on flashing and beeping every two minutes...How do I get it to unlock?
  • kjway Dec 09, 2007
    The oven door suddenly locked and will not allow me to remove lock
    left the message board and went down to try some suggested solutions. NOTHING worked.
  • Anonymous Dec 11, 2007
    door won't open locked
  • gouldjm Dec 13, 2007
    My oven is doing the same thing and I cannot get the oven to work OR reset the LOC message. The manual gives no directions. The oven has no self cleaning function and NO LOCK so the message light is a complete mystery
  • HildaMD Dec 14, 2007
    LOC on my jenn air SCE03600 range
  • Anonymous Dec 22, 2007
    I have an older Tappan self cleaning oven. I set the self cleaning mode and now after 3 days the door still will not unlock. Does anyone know how to either bypass the lock, unlock the lock, or somehow open the door?
    Please email me at [email protected] ASAP. Many thanks.
  • atenas45 Dec 26, 2007
    I set the oven to self clean. It made a cracking noise. It showed a number F90. and then it stopped. Now the oven door will not open. Help!!!
  • Anonymous Dec 27, 2007
    Used my self-clean oven and all went well, except now the door won't open after 24 hours.
    I have read the troubleshooting suggestions and there are none.
  • Anonymous Jan 08, 2008
    Am unable to open oven door after interrupting the cleaning sequence. How do I unlock it now?
  • Anonymous Feb 10, 2008
    error f30
    the oven door is locked and will not unlock and i can not usse the oven
  • Anonymous Mar 04, 2008
    racountertop locked
  • nnnnnnnnn Mar 10, 2008
    turn the main breaker off for 15-20 min and it should reset the unit
  • Anonymous Mar 13, 2008
    same problem-I was cleaning it- stopped the cleaning because it was smoking - should have cleaned a bit first - then flipped breaker - to turn power off -
    Now power on - door stays locked can not open- Please help-
  • ksml Mar 22, 2008
    I purchased older model used oven and when we first plugged it in, the loc light came on and the buzzer sounded and wouldn't go off. We unplugged it and the buzzer stopped, but when the door was locked the next time it wouldn't unlock at all.
  • kitten4you22 Apr 20, 2008
    use my self cleaning and now the lock wont come off hrlp
  • Anonymous May 27, 2008
    I fixed it by turning the timer to 1 min., holding in the oven light button (inside door) and clear button at the same time. It only took a few seconds for the lock to disengage and the door to be able to close.
  • Anonymous May 30, 2008
    Comment by Guest, posted on May 27, 2008
    I tried this advice and it worked thank you so much
  • jshaw714 Jun 12, 2008
    door locked is flashing I can not clear it
  • Anonymous Sep 15, 2008
    Thank you. It worked. I turned the timer to 1 min., holding in the oven light button and clear button at the same time. When the oven blinked "END," I pressed "Timer Off." Door unlocked. Yeah!
My oven door was locked with the door open. Tried turning off power overnight. NO help. Tried to get my mechanically challenged husband to fix it. NO help. Thank God for your website! I set the time to 1 minute, held in the oven light and pressed the cancel light until the timer counted down to 0 (zero). I am a cake baker and would have been freaked out to have to but another oven.
Posted on Jun 10, 2008
The door latch hook pulls door and swing to close. The door unlatch cycle takes 60 sec. If it does not unlatch, Slide a thin wire below the latch from side of the door and then try to make a "U" shape of the wire arround the neck of the door hook and pull the latch from side. I used sodering wire.
Posted on Feb 08, 2008
Maytag Range:
What worked for me was - holding the oven handle and lifting up on it and moving it left to right, back and forth, you will feel it fall into place and it will pop right open for you. This happened to me twice already and worked both times.Don't bother calling tech support they only want to send a technician out, and that will cost the same as a new range top. Hope this works for you. Good Luck!!
Posted on Feb 04, 2008
We unplugged the unit and started it again. It worked! We were nervous because this is why we had to purchase a new oven. the cost to repair the old was just short of buying a new one.
Hope this helps somebody in the future. Our model barely shows up on the web from a popular manufacturer. That was interesting!
Posted on Jan 26, 2008
Pull the plug to unit and replug it.
Posted on Dec 31, 2007
My oven has been cool for a day still nothing :-(
Posted on Nov 23, 2007
If you find yourself with a lock latch in the lock position with the door open (maybe as a result of opening the door right after activating the clean process before the latch has set) you should be able to correct it by pressing the "Clear Off" button and waiting awhile. Even after awhile it will not de-activate the lock until you "fool" the oven to think the door is closed by pushing in on the oven light activator switch located on the door panel for a few seconds. Good Luck!
Posted on Nov 22, 2007
I just unplugged it for a while and let everything cool down after the self cleaning..
  • 473 Answers
If wiring to door lock motor are ok then the motor may need to be replaced. Need to check the resistance of the motor with a meter. If it checks open then the motor is bad.
Posted on Oct 05, 2007
Puling it lightly up and moving it sideways did the trick for me. at least it opened it .. now I have powered it down and waiting for it to cool
Posted on May 03, 2008
SOURCE:
Samsung gt s5230 unloc
Hi, You can unlock your Samsung S5230 safer and easier using unlock code. you can get the accurate unlock code for your Samsung S5230 from www.TheUnlockSpot.Com at affordable cost with free step by step unlocking instructions. Good luck mate.
Jan 31, 2013 | Cell Phones
I changed the BCM on my 2001 Chev Impala. Now my car radio says "LOC"
you'll have to unloc the radio. you sill find the code and instructions in your owners manual
Aug 26, 2010 | 2001 Chevrolet Impala
My error message says FC the oven door is locked I tried unplugging but that did not work . The cleaning cycle was stopped right after it was accidently started.
The self clean option usually can't be stopped once its started. you may have to let it finish its cycle (a few hours) and see what happens from there. It also sounds like you could have a bad door sensor switch.
Aug 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
PLEASE HELP. Dead battery on 1989 BMW 3series with power locks.
Why dont you call loc smith to unloc the doors
You could take flat screw driver to try push the latch side ways where it latches
Jul 29, 2009 | 2001 Porsche 911 Carrera
Replaced battery now radio shows loc on 1995 monte carlo
Normal 0 I work at a GM dealership is CA and I’m sorry to have to tell you this, but you will have to take your car to a local dealership and have them unlock the radio for you. It doesn’t take that long but they will probable charge you something for the service.
Mar 20, 2009 | Motorola Car Audio & Video
1997 tahoe loc code
remove the radio it has a # on the back of unit and call the dealer with that #
Mar 09, 2009 | Oldsmobile 98 Cars & Trucks
Put the oven in Self Clean mode for 3 minutes and then cancel.. if if that will release the relay that controls the lock. If that doesn't work, Unplug the oven for 10 mintues, then plug it back in holding the CLEAR button down. If neither of those work you will need to contact a service repair man.
Jul 19, 2008 | Ovens
RB787W H1WW UNLOC CODE ERROR
If you have a multimeter check for resistance on the lock motor. Can access from the back by taking the panel off.  Make sure you unplug the range first.  If the lock shows open then it is bad and causing your problem.  Most likely this is your problem.  The motor has to be good for the oven to work.  Let me know what you find.
Oct 21, 2007 | Hotpoint RB787 Electric Kitchen Range
Frigidaire GLEFM385D Electric Kitchen Range Logo
6,489 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
