Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Error message C4551 anyone? pretty please.
Error displays on main screen stating "malfunction detected. Please call your technical representative" C3451 Any one know what that means and how to fix it? Kindest Regards
  • Anonymous Nov 22, 2008
    This is reser unitto error
    Problem Solver:
  • 12 Answers
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Posted on Dec 28, 2008
    New Friend:
  • 3 Answers
Utility counter>> chick details >> stop00stop01 >> password is 00000000
>> reset counters >> problem resolved .
Posted on Oct 16, 2012
  • 167 Answers
This indicates you have a reoccuring error or faulty part. You MUST place a service call for this.
Posted on Jan 08, 2008
2 Suggested Answers
SOURCE:
Kevin Hayes
  • 167 Answers
SOURCE: Error C3451 ! Anyone? Pretty Please.
This is an indication of a reoccurring error or faulty part. You MUST place a service call.
C450 c-0204
Remove the 2nd draw and ensure no paper behind it, THEN REMOVE ALL PAPER IN THE DRAW ON THE LEFT SIDE IT IS NOT A STORAGE AREA!!!! IT is use for 11 x 17 paper, or you have a burned out motor worse case a burned out motor that took the main control board that controls the motor also.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 24, 2014 | Konica Minolta Office Equipment & Supplies
C-2557
C 2557 - ATDC sensor error.You need to replace the developer in imaging unit.
Jan 03, 2014 | Konica Minolta Office Equipment & Supplies
A Malfunction was detected. Please call your technical representative and provide code. C4553
CAUSE: Failed laser unit (C4551 - Cyan; C4552 - Magenta; C4553 - Yellow; C4554 - Black).
SOLUTION: To confirm the failure of one of the laser units, perform the following:
1. Power the copier OFF and remove the power cord from the wall.
2. Switch the position of the laser unit with one of the other laser units.
3. Plug in the power cord and power the copier ON.
4. The failure code should change dependent upon the new location. Replace the laser unit as necessary.
Jul 24, 2012 | Minolta Di251 All-In-One Printer
Whenever i try to photocopy it states that malfunction was detected please call your technical representative and provide code...........cof32
What is the MAKE & MODEL? I'm guessing you have a Minolta??? You need to clean the drum unit & the ATDC sensor or replace the OPC
Sep 15, 2010 | Office Equipment & Supplies
Malfunction(Code 3451) of Bizhub C252
This is a fuser heat error. The fuser unit is located in the area where the paper exits the machine. It heats up and "fuses" the toner onto the paper. The error code means that it did not heat up properly. This means you will most likely need a service person to come out and diagnose the problem.
You can try to reset the error but I doubt it will help.
Turn off the MAIN power switch (not the one on the control panel)
Now hold down the utility key while turning on the main switch and continue holding the utility key for at least 10 seconds. You should see a screen come up with nothing but "trouble reset"
Touch trouble reset and you should see a small "ok" come on. Then turn off then on the main switch again.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Office Equipment & Supplies
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Jul 03, 2009 | Office Equipment & Supplies
Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
May 12, 2008 | Konica Minolta bizhub C250 All-In-One...
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Milota Bizhub C250 Error Message
First power off the printer completely. Then power it back on while holding the UTILITY/COUNTER button. You will see the minolta logo, then you will see a troubleshoot reset button. Press it, you will see an OK result. Power off the printer again, then power it back on without holding the button and everything should work.
Aug 13, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
1,456 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
