Question about HIS H487F512P RADEON HD 4870 HDMI Dual DL-DVI HDCP 256bit GDDR5 PCI Express 2.0 X16 Video Card..., PCI Express
Yellow lines on my screen
I'm having a little problem with my graphics card. i'm getting alot of back ground yellow lines on my monitor screen i know it much be the graphics card as ive tried the computer with my new HD tv and still the lines remain. is there anything i can do to sort this out. ive tried updating the drivers and making sure the graphics card is'nt loose. many thanks ian
  • 45 Answers
Re: yellow lines on my screen
Appears that your graphics card might not be seated properly, re-seat it and try again.
Posted on Dec 21, 2008
  • 119 Answers
Im  afrraid your graphic card is is a ram problem I think,from the grafic board...but...still damaged..
try with  an ew ati graphic board
Posted on Feb 03, 2008
0 characters
3 Points
I have a fx 5200 but when i was moving and stopped and unpacked then i set up my computer. the first thing that happen was that my monitor had lines going up and down on my screen. so im wondering do i...
Hello and Welcome to Fixya!
Lines running on your screen can probably mean that there is a hardware issue involving your monitor/LCD. In order to separate this, here are some things that you can try :
  • If you're using a desktop PC, remove the video card and enable the onboard video(in BIOS) - if the problem continues, then there's a need to update the video driver or replace the graphics card.
  • Try a known good working monitor, if the problem is not present, then it's clear that the monitor/LCD needs to be repaired or replaced.
  • Boot to BIOS and check if the lines are still there - if it is, then again the problem is attributed to the monitor/LCD.
After identifying the problem, my recommendation is to contact the manufacturer (or reseller) and check for warranty coverage (et. al).
I hope this helps, Thank you for using FixYa.
Oct 30, 2010 | XFX GeForce FX 5200, Graphic Card
Hello I have an hp 6820s notebook.when I power it up it has weird colors - blue lines all over the screen. i reinstalled the drivers but after a little while the problem comes back.... Also the laptop...
connect it to a regular monitor - if it looks good your laptop screen is bad.
If the external monitor is bad, then the video hardware in your laptop is bad.
Jul 13, 2010 | Graphics Cards
My screen is covered in wavy yellow lines that were not there before.when i tried running one of my games my pc crashed and when i turned it on it gave me a bluescreen which i did not have time to read. i...
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
May 21, 2010 | XFX NVIDIA GeForce 8500 Graphic Card
I do get withe or green lines across the screen when playing big movie files and some this when there is a load on the screen the computers freezes and the screen is black when it starts up number of...
It could have something to do with the graphics card but the lines that show up have me thinking that it has to do with the monitor. The only way to know for sure is to hook up the monitor to another MAC and if you still get lines then you'll know its the monitor. If your still unsure, get the Radeon 1900 graphic cards upgrade kit replaced, if you still get the lines then you'll know its the monitor, if the lines go away then you know its the video card.
Apr 22, 2010 | ATI RADEON X1900 XT Graphics Upgrade Kit...
Vertical lines on monitor, normally pink
I have had that very same problem before. Unfortunatly it is all bad news. The card is going bad. You will have to replace the card. I wish there was something else I could tell you, but I know with 100% certanty that the card isnt any good. And the reason your other graphics card may not work is due to you not either uninstalling the 7500 drivers before you swapped, or some of the software affiliated with the 7500 were not completly removed during the uninstall process. Try this program to completly remove all dirver files for the 7500.
Feb 20, 2010 | ATI RADEON 7500 (64 MB) PCI Graphic Card
The icons have purple color only
Couple of things, video card not in correctly either where the monitor plugs in or the card may not be correctly seated in the slot. Bung monitor even
Worst case scenario some of its video ram maybe damaged, I have seen similar issues, such as yellow lines down the screen and the like..
good luck :0
Mar 22, 2009 | Ultra ATI Rage 128 Pro Graphic Card
No picture on tv
Move your mouse over to a empty part of the desktop and press the right mouse button. Select properties.
Make sure that your tv is connected to the computer, that it is turned on, and that it is set for line input on that device.
Select the settings tab. You should see this box appear.
Monitor one is your computer monitor. Monitor 2 is your tv. It should be greyed out. If you move the mouse over to 2 and press the right mouse button make sure the attached is checked off. If not do this right now.
You may have to click on monitor two as well and select the advanced button on this screen. Then look in the settings to turn the tv on (this happens with ATI cards, NVidia cards may have a similar setting as well). Once it is turned on and you hit apply the picture should come on the screen. If you check off extend windows desktop onto this monitor, you will only see the desktop without any icons. Make sure that feature is disabled when you use monitor 2 (by default it is).
This should keep you busy to get it to work. Let me know if you need anymore assistance on this.
Feb 14, 2009 | XFX GeForce FX 5200, Graphic Card
uninstall ALL video drivers reboot computer should reboot with standard windows video drivers does the screen still play up if so you may have faulty video card.let me know please
Jul 17, 2008 | ATI Mobility RADEON Graphic Card
Graphics question
the problem comes from your graphic card,as far as i know that's a AGP card so next thing u could do is open your computer case take the graphic card out from the AGP slot and clean the slot and pins from graphic card with some contact spray or alcohol wait until spray or alcohol vanish and put the graphic card back power on and see the results
Apr 23, 2008 | XFX NVIDIA GFORCE2 MX 200 (64 MB) Graphic...
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
HIS H487F512P RADEON HD 4870 HDMI Dual DL-DVI HDCP 256bit GDDR5 PCI Express 2.0 X16 Video Card...,  PCI Express Logo
1,219 people viewed this question
Top HIS Graphics Cards Experts
phoenix chi
phoenix chi
Are you a HIS Graphics Card Expert? Answer questions, earn points and help others
