Question about Kenmore 50522 / 50524 Side by Side Refrigerator
My refigerator and freezer are not cooling enough
I turned my refigerator and freezer temperature to coldest setting. Freezer seems to be cold enough but not cold enough to Freeze the items. The refrigerator though doesnt even cool. What should i do?
  • 3 more comments
  • geossite Jul 08, 2008
    My Kenmore Mod.596.79272992. The bottom freezer operates Ok, but the refrigerator will not cool any lower then 60 degrees. I cleaned everything under neath, the fan is operating ok.
    Could it need an upper thermostat?
  • Anonymous Mar 14, 2014
    fridge and freezer not cold .temperature setting turned to coldest
  • Anonymous Mar 15, 2014
    Just bought a whirlpool refrigerator March 03, 2013, without extended warranty. Freezer is ok, but refigerator is NOT cold anymore.
  • Anonymous Mar 21, 2014
    Freezer not reaching dersired temperature
  • Anonymous Mar 26, 2014
    refrigerator not cooling to set temperature nor is freezer
  • 447 Answers
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
  • joey  shearer
    joey shearer Oct 04, 2007
    There is a defrost timer that initates defrost for 30mins every 8hours of compressor run time.
    I believe it is on the bottom of the controls. It will have a hole in the console and you should see a pastic cam you can turn with a flat screwdriver. If you dont see a hole, but you do see 2 phillips screws than it may have a circuit board called an Adaptive defrost control. If you see the cam rotate click by click till unit shuts off (you will hear louder click and fans and comp will shut off. Now its in defrost. Wait 5 mins is the lower back of the freezer warming? Hear any melting of ice?? If not than you need a test meter to diagnose further.
    Please rate my solution as solved and ill keep the help coming!!!!!!!!!!!
SOURCE:
My frigidaire upright freezer has been working fine until about 2 weeks ago. Now pizzas aren't freezing and freezer corn is soft and i put a ham in it and that was a week ago and it is not froze.
There should be a temperature adjustment inside the freezer somewhere. It will look like a slider or a dial, and be labeled something like "Colder" and "Less Cold" on opposite ends of the scale. If this is set to its coldest setting, and the temperature still is not cold enough to solidly freeze food (ideally, a freezer's temperature should reach ZERO degrees Fahrenheit), then the unit needs to be serviced by an appliance repairman.
Nov 30, 2017 | Frigidaire Freezers
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refigerator / freezer not cooling properly
You have a bad defrost heater.
READ THIS PWEASE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Amana Refrigerators
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
1,012 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
