Question about EuroCave Performance 283 Wine Cellar
Hotpoint refrigerator not cold
I own a Hotpoint side by side refrigerator/freezer model CSX22BCBK WH that about 6 years old. The refrigerator slowly gets warm over about 2 weeks. I must defrost the unit and it will work again for another 2 weeks. Frost appears on the back of the freezer after about two weeks and the temp goes down on the refrigerator about the same time. What can I test on this unit to find the exact problem. I did clean the coils, what little is showing under the unit. It is almost completely sealed. Thanks in advance for any help.
  • 447 Answers
There is a defrost timer that initates defrost for 30mins every 8hours of compressor run time. Take off the thermostat knob and the freezer damper knob, remove light guard. To the right of the thermostat, is the timer advancement screw it is small,and it looks like a plastic cam not a screw. you put the flat blade of a screwdriver and rotate click by click till unit shuts off (you will hear louder click and fans and comp will shut off. Now its in defrost. Wait 5mins open freezer remove lower bin look at drain hole where frost buils you shoud see the heater glowing red melting the frost. If no red glow and no heat from panel. You must go further with the diagnosis.. A solved rating will keep this expert advice coming...........
Posted on Oct 03, 2007
    Habit-Forming:
  • 174 Answers
This sounds like a timer issue.the timer tells the unit when to run and when to defrost.
Posted on Jun 11, 2009
SOURCE:
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Hotpoint fridge freezer ffa60 frost free bottom freezer has stopped working top fridge is ok 6 years old help!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
Age of hotpoint refrigerator
There's a date code on the label with the model number. If you enter all the other info from that label, I think I can track down the year/month that it was made.
Aug 03, 2009 | Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Freezer not getting cold enough
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
EuroCave Performance 283 Wine Cellar Logo
1,201 people viewed this question
Top EuroCave Refrigerators Experts
Marvin
Marvin
STEVE
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
