Question about Paradyne (6211-A2-200) Router
Paradyne Dsl Modem
I would like to use the usb port on one pc and the other port on another pc is ther any drivers or config. for this
  • Anonymous Nov 20, 2007
    paradyne not sharing on the internet
  • Anonymous Mar 01, 2009
    i have paradyne 6381-a3 router can i hook up 2 computers to it for the internet at the same time how do i do this and what do i need
    Brigadier General:
  • 6,966 Answers
Hi, If I understand you right, what you want is to use your Paradyne 6211 modem to share the Internet connection to 2 PCs. One is connected through the USB and the second through Ethernet port. Tried it on a Siemens 4200 and a Prolink Hurricane 9000, both worked and can be done. To be sure, the IP settings of the PC connected via Ethernet was set to manual configuration. In your case try IP 192.168.1.3, Subnet Mask 255.255.255.0, Default Gateway 192.168.1.1, DNS Servers - whatever your ISP are using. You of course can try and see if it works in your modem. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
I can connect to d-link by cable but i can not by wireless
may you need the driver of wireless card scan you pc from here end download driver if thet what you need www.ma-config.com
Jun 17, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a paradyne 621x modem that need drivers and dont have a **** for it so how do i go about downloading them from the internet
Is this a DSL modem? and if you need drivers then are you trying to install this thru USB connection only?
Aug 09, 2010 | Paradyne Computers & Internet
Driver Paradyne 6205 aDSL Modem 6205-A1-000 for win 7
if you can see a vista driver downloadable from the manufacturer's site, it will work 80% of the time.
Nov 06, 2009 | Paradyne Hotwire 6205 DSL Modem...
HOW TO CONFIGURE MODEM OF PARADYNE(ADSL 2+)
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Aug 16, 2009 | Paradyne (6211-A2-200) Router
Ethernet port not working. can i connect from my dsl by using a usb cable instead.
Yes, if your dsl modem is equipped with a usb option, you can hook it up to your computer but remember to remove the ethernet cord 1st. Both ethernet and usb cannot be connected at the same time. Once connected, your machine may search for a driver to install the modem via the usb port but it should work, especially if it's a westell. Best of luck.
Greg
Aug 05, 2009 | Compaq Presario 5000 PC Desktop
Using both USB and Ethernet to connect to the internet
Does your router suports usb ports, normally routers do not support usb ports, please check if your router first suports usb ports
Jul 22, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Hey
check if your computer is getting a valid address from your modem. if so, try to ping the modem's address and check if you'll have replies. if it'll reply, try to disable any antivirus software and firewall installed on the computer or try to use another browser. if not, check i the computer is properly connected to the modem, try to use another port or another known working cable. also try to use another computer for isolation.
hope this'll help you with your concern.
May 29, 2008 | Paradyne (6211-A2-200) Router
Connection of Paradyne 6211 to iMac (OS 10.5) via Ethernet
If you connect by using LAN port (RJ 45) you don't have to install driver. However USB connection will require driver. Do you have Ethernet adapter installed to you iMAC? If you have it will be resolved easily without using USB port. Check the following link for connection instructions
http://www.fixya.com/support/p200812-paradyne_6211_a2_200_router/manual-18800/page-18
If physical connection is successful you can go to internet browser type 192.168.1.1 and check your modem's settings. Please post if you need further assistance
Good Luck
Jan 27, 2008 | Belkin (F5D7233) Wireless Router
Is there anyway to do a remote reset of a dsl modem?
The answer "depends." If the DSL modem is in bridge mode, then NO. If you have opened up a WAN management port in the DSL modem, then YES. If the modem's management port is not open to WAN access, then do what I do. Remote into the site, past the DSL, then go backwards into the LAN portion of the DSL and reboot it. But..of course these answers are too easy and not what you are looking for, probably. The DSL provider can reboot the dsl modem. But there is no software or command I'm aware of that can reboot or resync a "fritzed out" modem. ZT3000 "Beta tester of "0"s and "1's"
Mar 27, 2007 | Paradyne BitStorm 4800
Router
You would have to refer to the manual to set up the usb connection, so as the router knows that the main pc is connecting via the usb and not the rj45 port. The only other thing may be that your router will recognise when you are connecting with the usb port, as long as it's the pc with the modem drivers on.
Oct 27, 2006 | Paradyne (6211-A2-200) Router
Paradyne (6211-A2-200) Router Logo
488 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
