Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Posted on May 01, 2009
Pictures too dark. Shutter operating too slowly.
Pictures too dark. Shutter operating too slowly. Battery is fully charged. Does matter if it is in fully auto or manual. Have hardly used this camera. Nikon D40 SLR. Should have gone to a reputable camera shop and received service.
ss
  • Anonymous May 22, 2009
    I am having the same problem. Worked well for 5 months and all of a sudden it went dark
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
2584
Points
11
Are you in auto mode? If it is manual then it is possible that the settings are not correct for the light. You can look at the meter to see what the camera thinks about the exposure.
It sounds as if your subject is too dark. Does this happen when the area is brightly lit? Does the flash fire?
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
My shutter speed is very slow and when I take pictures I think when it's dark is when I notice the problem but the picture will not take. Also if someone moves their face is blurry.
What mode are you shooting in? It seems you may either have your shutter speed set manually to a slow speed or, alternatively you have set your apperture set to a high number e.g f/20 or there abouts. Because this is a very narrow apperture the camera will compensate by using a slow shutter speed.
Try some shots in fully automatic mode and see what happens. With a slow shutter speed you can expect any movement to produce blurred images.
1helpful
Our new battery won't charge up fully, and is gradually going down 1% every few days. Now at 95%. Just like why we replaced the last batter.
a battery will not hold full charge when its not being used it will slowly lose charge over time keep your battery in a dark cool place if it is connected to your thinkpad it will gradually lose charge
hope this helps
I purchased a Quantum Turbo sc battery pack charger and I am using a Canon 5D along with the Quantum Turbo sc battery charger. Batteries fully charged. Connections are correct and fitted tightly. All...
If you have the camera on continuous then it may be that the charging is not keeping up with the shutter. Check the recycle time on the flash and compare with the burst speed on the camera. The burst speed on the 5D is fairly rapid.
When I take indoor pictures, the images have become progressivley darker and I have to adjust the white balance to +2 and the flash to almost plus 2 just to get a picture where it used to take great...
Make sure your battery is fully charged. If the battery is not fully charged your flash may not fire at the brightness you need to take a well exposed photo. Also, check your ISO settings. Try taking photos at a higher ISO when the subject is in a dark area. Experiment with the ISO. Good Luck!
2answers
Blurry pictures
Both of these problems are caused by underexposure. There are several causes for this. If you are set in AUTO MODE check the shutter speed and lens opening in the view finder. If the speed is less than 100 and the shutter is less than 5 and you are not using flash. You will probably get blured and dark pictures.  Practice shooting with your settings outside in sunlight , inside with lamplight, inside with flash and all of the above with motion. Check the exposure after each shot and make adjustments. In a short time you will get very good at setting your camera.
4helpful
2answers
DROPPED NIKON d40, now my pictures are all dark
First u have to reset the camera,go through the menu and select reset and yes. the camera will take default settings.Try now.
Reset the camera opening the connector cover.
You try with a different compatible lens .If works we have to change the lens.
Remove the battery and get fully charged .Operate all switches for some clicks. then put the battery and try.
Then u have to consult a mechanic.
Dark LCD screen
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
