Question about Archos AV 500 400-Hours Video Recorder
My AV500 keeps rebooting, it might run for 20 minutes or 20 seconds, but that makes it very difficult to watch a recording. Everything else works as it should and it has not been dropped or sustained any damage - it just started doing it. Any help would be appreciated. thanks.
  • turbotimbo Oct 09, 2007
    Thanks for the suggestions. Do you know where I can find instructions on how to remove the hard drive? Will it be okay with a format from a PC? If I do format it, how do I reload the OS? Thanks.
    Genius:
  • 1,139 Answers
If possible it may be the hard drive, try changing out the hard drive and see if it continues to reboot. Also try reformating that hard drive. it may be a bad logical sector causing the problem in any event look at the hard drive first and the if it is ok, concentrate on a possible power supply problem. If both of these prove to be not the problem, see if you can do a software reload or upgrade. As this might also be an OS issue.
Posted on Oct 08, 2007
  • Anonymous Oct 09, 2007
    The AV500 employs a disk lock feature however this has helped some people, Remember you do this at your own risk.
    NOTE: This is a guide showing how to replace a hard drive in a failed AV420. By doing this you void the warranty and risk damage to the unit. If you follow these instructions you do so at your own risk and I take no responsibility for the outcome of your actions.
    THIS GUIDE IS TAKEN FROM NEWMP3TECHNOLOGY.COM THE ORIGINAL AUTHOR IS COLIN SMITH. I HIGHLY RECOMMEND NEWMP3TECHNOLOGY FOR REPLACEMENT PARTS FOR ALL ARCHOS PRODUCTS.
    Take out the battery as normal
    Remove warranty sticker from battery area revealing screw (ONCE REMOVED THERE IS NO GOING BACK, - YOU VOIDED YOUR WARRANTY)
    Remove 2 screws on end of case next to compact flash card
    Remove screw on opposite end of case next to power socket
    Remove small screw from battery area
    Unclip protective corners by pushing up and in (they do not come off, just release from case)
    Unclip case from bottom black plastic strip connecting corners in the center (you can see the case is notched below the CH in ARCHOS below the screen) I used a small flat blade screwdriver pushed carefully at the notch.
    Turn over and unclip case center at opposite end (mic tv-lcd) to free center strip
    Remove case bottom and back now
    Fold screen back to reveal Torx screws holding hard drive.
    Remove Torx screws to free hard drive.
    Turn over and remove disk from connector.
    Connect the new disk and turn over, replace Torx screws.
    Rebuild case by reversing the instructions above.
    Once rebuilt with battery in place, power on and reformat disk when prompted by unit.
    Recover your files from your backup archive and you're done.
    PLEASE NOTE THAT THIS DRIVE HAS ONE PLATTER, THE ONLY OTHER AVAILABLE SIZE THAT WILL FIT THIS MODEL IS A 30GB SINGLE PLATTER. MAYBE IN THE FUTURE THE SIZE WILL INCREASE BUT AT THE MOMENT THIS IS IT. THE DOUBLE PLATTER DRIVES ARE TOO BIG AND WILL NOT FIT.
    IF YOU ARE THINKING OF PURCHASING THIS UNIT ONLY TO UPGRADE THE DRIVE TO SOMETHING BIGGER THEN 30GB THEN YOU MIGHT AS WELL BUY YOURSELF A NEW LCD SCREEN AND CHANGE THAT OUT WHILE YOUR AT IT, YOU WILL CRACK THE LCD WHEN YOU TRY TO PUT THE UNIT BACK TOGETHER.
SOURCE:
My sekonda watch is losing 20 minutes or so a day but if I don't correct the watch it carries on as normal running 20 minutes behind if I correct it the next day 20 minutes are lost
Firstly, have you tried changing the battery?
Secondly, have you tried setting it 20 minutes ahead, to see if it rectifies itself over a day or so? It may be that the mechanism has gotten a little sticky.
May 19, 2017 | The Watches
Hello. I have a Seiko 7t62 ojpo chronograph. The small second hand will run for about 20 minutes then stops. As a result, the main minute and hour hands stop working. Everything else works. Any ideas?
You have a fairly premium watch and some versions are more premium than others. Your watch clearly needs attention and that should be entrusted to a Seiko dealer or to the manufacturer. Once the case has been opened the sealing must be retested to ensure it meets specification. If this isn't done as part of the repair or service or battery fitting there is little point in having a watch with such a high specification.
Jan 04, 2017 | Seiko Watches
What are the three little faces for? do not have instructions
Your watch is a chronograph or a watch that includes a stopwatch. Two of the three dials are for recording minutes and hours with the large sweep second hand recording seconds. Pushing the upper button starts and stops the stopwatch function. Pressing the lower resets everything to zero. The small bottome dial is the seconds hand for the watch, it always is moving.
Dec 29, 2011 | Callaway Golf Unisex CY2085 Collection...
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
MY TAG FORMULA 1 WATCH KEEPS STOPPING AT 11.20 BUT THE SECOND HAND KEEPS GOING.
mcdevito75 here, It sounds like the (larger) minute hand is leaning against the (smaller) hour hand, stopping the time telling past 11:20 while the seconds hand keeps going. You"ll have to see a Watch repair person and have them look at your watch. Best Bet, look for a small watch repair shop in your area.
Aug 25, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Blank White Screen
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Please RATE my solution at the bottom.
Best of Luck.
Nov 20, 2007 | SanDisk Sansa e200 MP3 Player
Recovery mode
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 02, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e260
Try holding the power button for 20 seconds to hard reset the device. Then try turning it back on. If that doesnt solve it, youll need to do the following. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 24, 2007 | SanDisk Sansa e260 MP3 Player
2 different "Recording" problems with my unit.........
i think you need to use manual button for increment track number
Jun 01, 2007 | Harman Kardon CDR30 2-Disc CD Recorder
Archos AV504 problem
you cannot change any thing on the AV,500GH the mechanism are built in to work on operating system 1.5.12.
Jan 12, 2007 | Archos AV 500 400-Hours Video Recorder
Archos AV 500 400-Hours Video Recorder Logo
160 people viewed this question
Top Archos Televison & Video Experts
Inky Fingers
Inky Fingers
Jaime Hernandez
Steve Sweetleaf
Steve Sweetleaf
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
