Question about RCA F35731MB 35" TV
Tv PROBLEM hI, I HAVE A SONNY TV AND RECENTLY WHEN I TURN IT ON, IT FLICKERS ON AND OFF FOR ABOUT 5-10 MINUTES AND THEN IT STARTS TO WORK NORMALLY. THIS IS HAPPENING EVERYTIME I TURN IT ON. DO YOU KNOW WHAT THE PROBLEM IS? THANKS
  • PAZZ Oct 04, 2007
    Thank you for your solution. The TV doesn't go off and on repeatedly. It is the picture. I can hear the sound but the picture takes 10 mintes to show and it starts to go off and on for some times(5-10 min) Thank you agian for your support.
  • 48 Answers
More than likely you have loose connections on the power supply board. Fixing the connections should take care of the problem.
Posted on Oct 03, 2007
My Mitsubishi WD-65638 turns on then flickers and turns off?
Flickering must be due to the fault to lamp itself. If you wish to get more details, check this link.
Mar 03, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
52 inch mitsubishi rear projection TV (4 years old) starts to flicker after about an hour of use. Kind of flickers from color to black and white very fast ans steady. Every time, the first 45 minutes to...
Hi
There is some loose solderings on the chroma board of your TV. This is a normal fault to all kinds of TVs. Some components, like resistors, will heat up during working. Repeated heating and cooling make its solder joints to get loose contacted. Here, your TV works fine for some minutes as you reports and the the problem arises. This is surely due to this kind of mistake. Just see, it is very difficult to locate the exact loose contact points. They will be microscopically minute, that we can't detect it with naked eye. The only remedy, as we techinicans do is, resolder all the suspected solder terminals of that section by applying a little more solder, without making shrot between adjecent soldering points. This is a very sensitive job, as it needs both patience and hand balance to solder. If you can, resolder all the hi-watt resistor solder terminals and IC solder terminals in the chroma section of your TV. You must have a good soldering iron with point soldering bit. If you are confident proceed. Otherwise, leave the job to any expereinced technican.OK
Jul 13, 2011 | Televison & Video
Sony grand wega turns off & o ever 30sec flashes green light
it's a power failure.try to replace the regulator in power supply board.
Sep 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
No Picture - only sound
I have a TV at work that has been doing the same thing here's how I've been getting it to show a picture:
turn the TV on then quickly change it to an input channel (like front or etc) that doesn't have anything connected to it. Let it sit there for a few minutes, then change it to a regular channel and see if you have a picture.
Apr 26, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Green light continues to flicker, TV will not turn on or off.
Unplug it for 30 minutes. Then try again.
Let me know and I'll check the service manual. I've got a 65511.
Feb 01, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Jul 05, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Really green picture with flashes
Hi...the flickering and the green is the colorwheel going bad. Very common for this model and an easy fix too.
Mar 28, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Televison & Video Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
