Amphion Mediaworks M-510 Portable DVD Player Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need replacement battery
I need a replacement battery for the alphion dvd player model m510. any help please?
Anonymous
Level 2:
  • Expert 55 Answers
  • Posted on May 01, 2009
Anonymous
Expert
Level 2:
Answers
55
Questions
0
Helped
24961
Points
143
You can try googling the internet or contacting customer support to see if U can get a replacement battery. Is the battery taking some kind of a charge? If it is taking a charge that lasts a short time, U can get by by checking the players ac in voltage. Example: If it is 9 volts, U can get a 6 d cell battery holder from the internet, and go to batteryspace.com and go into wires and connectors. Get the two prong wire that has an two alligator leads on the other end. You can buy a universal 6V-12V battery pack charger from this site, and get the powerizer 10000 mah rechargeable d cells to boot. U might want to use the .9 Amp setting, or the 1.8 amp setting if yopu are feeling adventurous. The powerizer batteries have sometimes leaked, especially the smaller C size when using this setting(1.8 amp) The site also sells compatible tips that will fit that connector. If the battery cannot take ANY kind of a charge, what kind of battery is it? If it is built in, youre in luck. If it is a clip on detachable type, U have a problem as the cutoff voltage with those type of players is typically higher on the ac in jack since the player isnt recognizing that discharged battery pack is still connected. For that, you could try a 8 d cell battery holder and just use alkalines if you don't want to risk cell reversal with your rechargeables, or just get the 8.4 Volt battery pack that site sells. I also recommend accupower evolution low self discharge rechargeables, found at thomas distributing.com id U have the cash. Good luck, and let me know how it turns out. Hint: the voltage rating of the battery power supply listed on the player may be lower than the AC in jack. Consult your manual. Use the specifications used in the battery listed. A 7.4 lithium ion pack or a 7.2 nimh battery pack will work if it is basically a 9 volt circuit. A 7.4 litium ion battery included with the player would mean you would use 6 D cells inserted in a battery holder hooked to this unit.
  • Anonymous May 04, 2009
    There is another thing. If U decide to go with a different brand of rechargeable, some brands may have tops that are a bit short. Some battery holders have a small plastic channel that may prevent proper contact with the positive terminal inside. In this case, use a Sperry battery tester available in hardware stores and bridge the gap with the metal part of the red lead
1helpful
Problem with the power cord it doesn't works
Ask seller Q.Wrong type,it will burn ur micro power board.
3answers
Need user manual for Amphion MediaWorks (AMW) M520 Portable DVD player
Hi, You should be able to get what you need from: PGE Corporation Limited Unit 3 Newmarket Court Kingston Milton Keynes MK10 0AG Tel: +44 (0) 870 1280 880 Fax: +44 (0) 870 1280 878
User Manual
Go to radioshack.com and search 1603910
soupie
Amphion mediaworks amw m510 portable dvd player
Amphion Mediaworks AMW M510 ~ Help I need a car charger
[email protected] Thanks
4answers
AMW MacVision M510 Portable DVD player
The user's manual is actually fairly easy -- go to radioshack.com and search for the catalog number "1603910". The only hit you'll get will be the manual.
I'm having no luck with the battery so far, however.
Top Amphion Mediaworks Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Amphion Mediaworks Televison and Video Expert? Answer questions, earn points and help others
