Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
MY SOUND PROBLEM
IN SOUNDPROBLEM MY HEADPHONE & MY SPEAKER NOT WORK PROPERLY(NOT DISPLAY)WHAT I DOING? PLEASE HELP ME.
  • 21 Answers
Firstly, restart you pc if you havent' done so. depending on your computer model, go to their main website and find the support section. Once you do that, see if you can find the exact model, then the list of drivers and it should be there.
Posted on Oct 03, 2007
SOURCE:
Piano does not work no sound can be heard power supply is on display is proper too. if head phones are used i can hear the sound. but no sound can be heard without headphones tried to play a song through...
I could not find the schematic for this, but other Casio units use a common voltage regulator amplifier chip to drive the speaker... I would firsst check that leads to the speaker have not become disconnected.
Jul 19, 2011 | Casio SA76 44-Key Mini Personal Keyboard...
Tip
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="http://www.ehow.com/computers/">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
Sony Home theatre system 7.2 Channel Muteki HTDDW-7500 Problem : No sound output from speaker. Power supply, Display & Channel Sellector all function in normal. I have test with Headphone plug-in to...
If headphones are not working when you have unit properly set to the input you are using then there is something seriously wrong with the receiver. Is the monitor button incorrectly on?
Aug 25, 2017 | Sony Audio Players & Recorders
Left speaker gives no sound
There could already be a problem with the speaker jack, if only one channel is consistently giving no sound on your system.
Try turning the male (connected to speaker wire) jack and you might hear a static crackle while doing this. If you get both channels to produce sound this way, you already have a failing audio jack, and may need replacement later on.
Hope this helps.
Jun 07, 2009 | MSI PM8M2-V Motherboard
Disabled Satellite A215 internal speakers and now can't enable!
you may want to try and reinstall the driver from the manufacturers website. I had to do that with a brand new notebook as the speakers didn't work when first turned on. I'll see if I can locate a link and post again if I find it.
Mar 31, 2009 | Toshiba Satellite A215-S7407 Notebook
Speakers have stop having sound
1. Please plug in a set of speakers or headphones known to be in working order.
a. If the known-to-be-in-working order speakers or headphones work, your existing speakers are faulty.
b. if the known-to-be-in-working order speakers or headphones do not work, your existing speakers are fine, and your sound card is faulty.
Mar 29, 2009 | Computers & Internet
My sound is not working unless i use headphones.
You need to check if internal speakers connection / cable is hooked up properly. You may need to open up the pc to see. If help needed on this, please as a technician to assist if you're not comfortable enough in opening it up alll by yourself.
If the connection or the internal speakers is busted, parts may need replacement.
Jan 06, 2009 | HP Compaq Presario CQ50-211NR Notebook
I cant take or make calls on my iphone without the headphones in.
Yea it sounds like the headphone have a sync problem. what you can do i go the Apple store and they should help you out they will swap your headphones and then it should work.
Thank you, Apple Care Technical Support
Jul 21, 2008 | Apple iPhone Smartphone
Soundproblem, Motherboard ASUS P5KR
Are they powered speakers? Try using the front panel headphone jack. The colored jacks under the 6.1 are configureable to be used by different speakers, like center channel, etc. Good luck in Vista or XP on a Vista MOBO.
Feb 13, 2008 | Computers & Internet
Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Jul 05, 2007 | Bose QuietComfort 2 Consumer Headphones
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
