The light on the control knob stays on in the off position, when the light stays on the clicking continues. Only when I slightly turn the the control knob towards the "Hi" position is when the light goes off and the clicking stops.
Sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Yes, the moisture is probably the problem...
Here
is a tip that I wrote that will help figure out why the burner spark
keeps on clicking...
Gas Range Repair Burners
Keep on Clicking
heatman101
