Question about Toshiba 32HFX71 32" TV
Sound help I was giving a mitsubishi TV no remote and when I hit the vol. up or down it said speaker off if I go and buy a remote can I get it off "mute"
  • 48 Answers
Model number please ?
Posted on Oct 03, 2007
SOURCE:
I need to know where on the display or remote where the settings for sound control for P42HD. I am trying to set the TV to use external speakers and don't know where the settings to change the sound are
Enter the on-screen menu by pressing Menu. Use the Vol+/Vol- buttons on the TV or the left/right arrows on the remote to select the Audio Adjust (second line) sub-menu. Use the Ch+/Ch- buttons on the TV or the up/down arrows on the remote to go to the line labeled Speakers (bottom of the list). Use the left/right arrows to toggle the internal speakers On or Off. Then press OK to save and press Exit to exit the OSD.
With your receiver/amplifier for your speaker system turned on, follow the directions for that unit to finish setting up the connection.
I hope this helps.
Mar 08, 2011 | Vizio P42HD Television
We have a DVR hooked up to our 1989-99 Mitsubishi TV (floor model) still in amazing working condition. The remote control for that TV never allowed us to put the TV on mute. If the mute botton was...
Well, without knowing the exact model of tv and remote, I can just give my best guess.
Try using the volume up/down on the TV and / or the remote.
On the TV, try pressing both the volume up and down at the same time.
Stick the remote right in the face of the TV (direct in front of the remote sensor) and hit the mute button.
Try tapping the mute button in very short single bursts rather than pressing it for a half second like you would any other button.
If any of those work, please come back and reply with the model of the TV and remote, because someone somewhere probably has the same issue and would love to have it solved!
Feb 24, 2011 | Mitsubishi Televison & Video
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
I have a mitsubishi cs 35305 and the speakers are off
Too old for on line tech help. If its an old tv it might have a switch in back of the tv to turn speakers on or off.
Apr 24, 2009 | Mitsubishi CS-35305 TV
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
Volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Aug 02, 2008 | Yamaha RX-V659 Receiver
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Jan 19, 2008 | Yamaha RX-V657 Receiver
Sound control is via TV remote only
You didnot mention wehther you selected external speakers on you tv. If your TV allows this then do that, first.
Also the sound input to your TV must come from some source, (cable/ Sat). You could remove the audio inputs to your TV and only allow the audio to go to your Receiver.
RCA cables will allow this to be easy just remove the red and white audio to your TV. If you have sent them to your reciever then you must balance the cable box volume (reduce to the lowest level , then raise your recievers vol until satisfied if you are to loud when you switch to a CD then raise TV vol until they match, so your CD doesn't play to loud when switching modes)
If you are using an HDMI cable to your tv than there has to be a setup for turning off the internal speakers on your TV.
Dec 03, 2007 | Onkyo TX-SR605 Receiver
Speaker off
You will need an original Mitsubishi remote. The original remotes usually have 3 large oval buttons labeled Audio (up and down), Adjust (up and down) and Video (up and down). Pressing the Audio button will bring up the usual Bass, Treble, Balance... and Speakers Off. When you see those words press the Adjust button and the speakers will switch to On. Some sets have the Audio, Adjust and Video buttons behind a little door on the front of the set, so check there first and if not, get an original remote.
Dec 29, 2006 | Mitsubishi CS-27407 27" TV
Toshiba 32HFX71 32" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
