Question about Canon CLC 1120 Color Copier
Canon CLC 1180 Copier / Digital Colour Printer Print Spreads
Machine does not show any error, however even after gradation procedure colour spreads near the image, expecially magenta. Company refused to give service manual stating that, that is a confidential document! Very very adament policy. Country head even doesn't reply our serious alligations regarding installation defects.
  • 69 Answers
Hi im jules_09 service manual are not given to clients because its a secret company keeps only there service enginer can avail to it.but if the colore spreads out check your developer or the entrance of each developer somtimes it the developer leak out specially if the developer seal is deffective
Posted on Oct 04, 2007
SOURCE:
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
Do you recommend Canon ClC 1180 for business
Depends on what you want to do with the copier. This a graphic's machine if you require high quality photo type output this is a perfect machine. It's not fast and will not run heavy stocks. It performs best with Hammermill color laser paper. If optioned with the Fiery Print Controller it will produce great print from photoshop and other graphics programs.
The CLC-1180 is Service intensive and will require frequent service calls and I highly recommend you have a service contract.
If you just require general office color such as Powerpoint , Word and don't require photo quality output, I would recommend the ImageRunner C-3200, ImageRunner C-3380 or ImageRunner 5180. These machines require less service and cost less per copy to operate.
Feb 19, 2010 | Canon CLC 1180 Copier
Canon irc5185 new machine, print not good
run auto gradation adust in add. func. on heavy paper then check each colour ! at a time it iis possible ! of the new drums has failed. good luck
Nov 20, 2009 | Canon Office Equipment & Supplies
Canon clc 1180 error code 071-0007
k you may have several problems you may take some canned air and blow out the connectors on the tx unit and the inside frame particularly the connectors on the lower right rear frame wall .. when you pull out the tx unit you may also want to turn the two cam gears on the lower left rear frame all the way clockwise then slide unit in
Jan 10, 2009 | Canon CLC 1180 Copier
Error E061 & 0070
grid bias at upeer limit
Dec 19, 2007 | Canon CLC 1120 Color Copier
Why wont my printer pirnt?
hi im Jules_09,check you connection to your computer r your cannon has to be reset because of the driver you installed
Dec 20, 2006 | Canon CLC 1180 Copier
Canon CLC 1120 Color Copier Logo
301 people viewed this question
Clive
Clive
old marine
old marine
Ekse
