Question about Westinghouse WST1810 Canister Vacuum
Emptying vacuum This may sound really silly of me but I cannot remember how to open the thing up to empty it! Help!
I had the same problem!
There is a video on YouTube that shows how to open it.
http://www.youtube.com/watch?v=1SYstrPyD2g
Jim
Posted on Dec 01, 2007
  • 3 Answers
The video is no longer active, but I figured it out anyway.
It is simply a hard pull out from the top of the silver container. The top will swing out and then you can take it off. I also pushed down a little bit, but I believe the main part to simply pull out. A fairly strong plastic tab holds it in place, so it took some force, but did not break anything.
Posted on Dec 08, 2012
SOURCE:
Release button to empty cylinder wont work cant get it off manually
Hello, the canister empty function works by pulling a long plastic rod that moves the catch on the bottom access door. It sounds like either the puller is stuck or that the rod may be broken. If the puller does move upward when pulled, then the later in most likely. You can check by removing the Torque screws and pulling the top section off very gently, because the canister really needs to be opened and removed first, do this outside to avoid a dirt spill in the house, either way I would look for a used canister from another machine, which is really a much cheaper and less dirty option.
Mar 07, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Help! i need to empty the dust compartment on the steam cleaner /vac and i cant find instructions
You need to ask again but give the MAKE and MODEL number of the machine, so we can help you.
Sep 14, 2014 | Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
My Dirt Devil KONE Hand Vacuum won't unscrew to empty
sounds like it may be cross threaded , or bits of grit holding it tight ,try tapping round the rim with screwdriver handle to see if it will loosen anything that's holding it ,then get someone else to help you hold one end and you hold the other end and twist..
Mar 11, 2013 | Dirt Devil KONE Hand Vacuum MO213BLU...
FITTED NEW CYCLONE UNIT TO dc07 ANIMAL AND CAN'T GET IT TO EMPTY
Hi Pauline,
I'm sorry to hear you're having difficulty fitting your new cyclone pack. If it won't empty when you pull the trigger, you may want to check you have the clear bin and cyclone pack aligned and fitted together correctly.
You might want to give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), as one of our advisors will be happy to help you check everything is correct with your machine.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 04, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Water spray not functioning for hose or carpet. I purchased this about 3 weeks a go. The spray work for about 20 mins then stopped. Is there are reset? I have tried turing off and on etc. Wendy...
Wendy,
I have the same model Bissell as you and this is going to sound silly....
The spray tank runs out of solution allot faster than you would expect it to. Remove the tank, dump out all the used stuff, and refill your solution tank.
You never know that it is empty until you dump out the waste tank! 20 minutes sounds about right for a full solution tank to run dry.
Good Luck! Thanks for using FixYa!
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell model 7901-1 won't dispense The pump turns, belt looks good Fluid from the reservoir is seen with a couple of bubbles in the inlet tube. It sloshes back and forth but doesn't get going
It's one of two things:
1. The Bladder may be empty. Remember, the bladder is inside the reservoir, so the bladder may look full, but in fact could be empty.
2.Or the lent screen may be clogged.
Jim
Oct 07, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Can't get it open to empty it! Help
1. Remove the unit from the base.
2. Twist the top clockwise to separate the two halves.
3. Grasp the filter tab to lift it up.
4. Empty filter, replace, reassemble.
May 22, 2010 | Dirt Devil KURV Hand Vacuum Champagne...
Fitting internal bin catch on dco7
Yea I can definitely help you. On the tope of the cyclone there are three screws that will allow you to take off the top off the cyclone. You should see a long black rod going down the middle of the cylcone. It is difficult and you may have to detach it from the top i cant remember as usually i just replace the whole thing and only done that 3 times. You take a flash light and you can see where the rod goes in and just push it down and it should pop open. ill check back on monday to see if you replied or need more help.
Dec 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Westinghouse WST1810 Canister Vacuum Logo
195 people viewed this question
Top Westinghouse Vacuums Experts
Kevin Getz
Kevin Getz
Tom Chichester
Are you a Westinghouse Vacuum Expert? Answer questions, earn points and help others
