Question about Lexmark P3150 All-In-One InkJet Printer
Want print I CAN'T INSTALL THE PRINTER ON MY WINDOWS 2000 I HAVE THE DISK IT STILL WANT INSTALL
  • Anonymous Nov 03, 2007
    have installed printer it says ready the all in one center icon doesn't show up but the printer says it's installed but when I go print it says handle invalid new computer is acer printer is p3150
  • 62 Answers
Any clues about what happens when you try to install. Does the install software run? Do you get any error messages? Might check that you are following steps on the setup sheet at: http://www.lexmark.com/publications/eng/3100/index.html
Posted on Oct 05, 2007
SOURCE:
Is the printerdriver easy to install?
Yes, follow this steps
Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Parallel port printers Windows 2000 and XP
  1. In Windows XP default view, from the Start menu, select Printers and Faxes, and then double-click Add Printer. In Windows XP Classic view, or in Windows 2000, from the Start menu, select Settings, then Printers, and then double-click Add Printer. This will start the Add Printer Wizard. Click Next.
  2. Select Local printer or Local printer attached to this computer. Click Next.
  3. Select the LPT port.
  4. Select the manufacturer and model for the printer you are installing. If you would rather use the driver disk that came with the printer, insert that disk and click Have Disk, and then browse to the driver disk and the proper folder. Click Open, then OK. Sometimes at this point, you will be asked if you print from MS-DOS programs. Most people can safely answer No here, but if you print from any DOS-based programs, answer Yes.
  5. Windows will offer a name for the printer that you may change if you like. If this is your only printer, or you wish to use this printer most of the time, select Yes to make this the default printer.
  6. You will be given the option to share this printer on the network. Unless you specifically want to do this, select Do not share this printer. Click Next.
  7. Make sure the printer is connected and turned on, and then answer Yes to print a test page. This will ensure that your printer is working. After the page has printed, click Finish. Your printer should be ready to use.
Oct 28, 2008 | Lexmark Office Equipment & Supplies
Is it difficult to install?
Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers: USB printers (Windows 98, Me, 2000, and XP only)
How do i set it up?
In Windows, how do I install my printer? Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
Oct 27, 2008 | Office Equipment & Supplies
Have lost disc for lexmark X125 can you help install this printer
To get your software go to:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
And download there your printer software
Oct 18, 2008 | Lexmark Office Equipment & Supplies
Hp diskjet 1280 printer
Hai,
I have provided the link to download the software depending on the PC operating system.
Windows XP -------> Download
Windows 2000 -------> Download
Windows Vista -------> Download
I would appreciate Feedback for the solution.
Thanks
Riz
Jul 26, 2008 | HP DeskJet 1280 InkJet Printer
Problem installing printer on Windows 2000
ok..remove the old printer, then go here for up to date drivers(do NOT use the cd)
Mar 12, 2008 | Canon PIXMA MP160 All-In-One Printer
Configure to print
You may print without the D-Link Printer software in Windows 2000/XP. Here´s how: Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer). Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next. Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next. Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next. Step 5 You will get a message saying that additional port information required. Step 6 Select Custom and then click Settings. Step 7 Set Protocol to LPR. Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this. Step 9 Select OK > Finish. Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
Configure to print
Feb 16, 2006 | D-Link DI-704UP - 4-Port Broadband Router...
Configure to print
Feb 16, 2006 | D-Link DI 713p Router (nwl-di-713p-r)
Configure to print
Feb 16, 2006 | D-Link DI-704P Router
Lexmark P3150 All-In-One InkJet Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
