Question about ViewSonic VX910 19" LCD Monitor
LCD Monitor has no video
Hi, My Viewsonic LCD monitor has quit working. The screen is blank, and I have tried it on other computers, and the power button flashes on and off at about a 1 second interval. Can you tell me what it is wrong and perhaps where to get the part to fix it?
    Scholar:
  • 116 Answers
Sounds your monitor has either blown a backlight or the inverter board is bad. Either way they can both be replaced, but tracking down the parts will be a bit difficult. But your LCD Monitor is in trouble! Sorry!
Posted on Nov 26, 2007
  • Herman Briggs
    Herman Briggs Nov 27, 2007
    Ok here is the deal about these LCD monitors. I am called atleast three time a week because of the same problem. Most of the time it is a replacement LCD. These monitors are very fragile as they have backlights that are very tiny florecent lights that allow you to see the image being displayed. When this light starts blinking it is for a number of reasons:
    1. Power supply not generating voltage to display an image
    2. Inverter board is bad
    3. Backlight is blown
    These can all be either fixed or replaced provided you determine the source of the problem and track down the replacement part.
    But I will try a power supply replacement first then take it from there!
Hi, I have a ViewSonic VX2235mw LCD Monitor it was working fine then all of a sudden the screen turned off and now it wont turn back on. The power light is on and is Blue but no sign of life in the screen...
This is a very common problem with this model after a few years of use. This problem is caused by a failure of the capacitors in the power supply board hat powers up the back lights in the monitor. When the back lights don't power up you get no display on the screen. Here is a link to a repair guide for that model that shows how to open the unit and what to look for and replace to repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Here is part one of the three part video repair guide posted at the above link:
Jan 29, 2013 | ViewSonic VX2235wm LCD Monitor
I replaced the video board on viewsonic vx2235wm-5 now video turns on then off
That is a power supply problem not a video board problem. You will need to either rebuild or replace the power supply to fix that problem.
Oct 21, 2012 | ViewSonic VX2235wm LCD Monitor
My viewsonic monitor has stopped working. When I boot my machine the start screen flashes and then the monitor goes blank. As the boot process continues, each new page flashes briefly then the screen goes...
Viewsonic LCD?
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 05, 2010 | ViewSonic Computers & Internet
Monitor with a blank screen
The monitor is about 2 years old, time to inspect the caps in the power supply first, look for caps with bulging top. The problem can also be in the inverter circuits, or bad lamps. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can help you more.
Mar 01, 2010 | ViewSonic Q191wb LCD Monitor
Optiquest q9b-2 blank white screen (lights up when powered up) no video ??no problem with computer, video fine on another monitor, tried this monitor on several computers same problem, blank white...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 06, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
I have a Viewsonic VG175 monitor. Out of the
The back light inverter may have gone out, You need to look for 12~18vdc feeding the board, there are also surface mouted fuse on the board,
Jan 03, 2010 | ViewSonic VG175 17.4 in. Flat Panel LCD...
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
596 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
