Question about Compaq Evo Notebook N115
Boot up problem
I got a used Compaq EVO N115 notebook and when I plug the power supply in and turn the computer on the lights showing the battery is being charged and a green light on the display turn on but the screen remains blank and the computer doesn't boot up.
  • WarAvocat Oct 04, 2007
    The ram looks ok when I removed it, but how do I really know? Other of my computers test the memory at boot but since this computer doesn't bootup at all I don't know that the memory or hard-drive isn't damaged.
    The lights do come on and the battery will charge and hold a charge. I have tried booting up with and without the battery but neither time did the computer boot up.
    Thanks for the help though.
  • WarAvocat Oct 05, 2007
    I live in Houston, Texas USA but I was hoping to discover the problem myself. I took out the added memory stick and tried to boot up using only the build in memory. That didn't work either.
    Thank you for your help though and any suggestions are helpful.
    Sergeant:
  • 457 Answers
It is possibly the RAM it may have ceased. Look at it underneath held in by two screws. Take it out and examine it then put it back. The motherboard seems ok because you said the lights are lighting up. Sometimes the ram can stop even the bios and nothing can boot up.
Posted on Oct 04, 2007
  • Peter Hirawani
    Peter Hirawani Oct 04, 2007
    I was going to suggest that you try the installation disk to see if that would boot up but you also state that the bios wont start. Normally if the hard disk failed the bios would tell you so it cant be that. You may need to take it to have it tested by a technician. Its a pity you have not said in which country you live in that way I may have been able to get you help.
  • Peter Hirawani
    Peter Hirawani Oct 05, 2007
    Well since you want to do things yourself Im just a bit concerned about you stating the computer does not boot up yet all the lights are going have you tried and external monitor in case the LCD on your machine is faulty?.
SOURCE:
Can not find operating system in evo n115
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty..Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jun 14, 2012 | Compaq Evo Notebook N115
Compaq Evo N610C
I think you have just to change the battery.It's nothing much you can do to repair it...Sorry!!!
Nov 17, 2007 | Compaq Evo N610C Notebook
Hi I,m looking for download new bios for a notebook compaq evo n115, as the ones are in are very old and my computer dosent work properly. do you know where can I download them? Thank you
Take a look at the following URL:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=uk&prodNameId=97138&prodTypeId=321957&prodSeriesId=96309&swLang=8&taskId=135&swEnvOID=1098#1670
Scroll down and look for ROMpaq (System ROM update). It is worth noting that HP / Compaq do not show a newer version than 2002, so it may be that your BIOS version is the current one.
As always, exercise caution when flashing the BIOS on any computer, as a flash failure can cripple a system completely.
Jul 23, 2011 | Compaq Evo Notebook N115
I have compaq presario evo 700 series2130 what battery does it have it came with out one
Check out this website.
http://www.dantech.ca/?q=10-25-379
Additional information:
  • Series CMB002A
  • For use with Compaq CM2090⁄CM2130
  • Compaq Spare: 247051-001
  • Compaq Part No.: 246437-002
  • Battery pack enhanced lithium-ion (LiON) 4.0Ahr rechargeable
  • LI-ION 14.8V 4.0AHr
  • Part Number 247051-001246437-002CMB002A
  • Compatible models:
  • Evo N115
  • Presario 712AP
  • Presario 700 Series
  • Presario 720AP
Jan 08, 2011 | Compaq Presario 700 470024-192 Notebook
How do you enter setup on a compaq evo n115
If you system has windows XP as Operating system, press F1 at the compaq screen to Enter Setup
For vista press F10 to Enter Setup.
Please get back for any further assistance
Mar 02, 2010 | Compaq Evo Notebook N115
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
I have a Evo N115 Compaq computer laptop and computer will not come on. The green light comes on when you push the ''on'' button but that is all. What do I need to do?
I have the same problem. When I follow these steps the laptop finally starts.
1) Let the bottom of the laptop somewhere you can warm up it a bit. Be very careful about this. The laptop´s bottom is made of plastic !. In summer I leave the laptop upside down under the sun for about 15 minutes and it´s ok.
2) Plug and unplug the dc connector (not the one at the ac outlet), wait until the small green led lights and inmediatly after it happens, press the power button.
3) Repeat step 2 as many times as necessary.
4) Do not shutdown the laptop. Always choose ´suspend´.
Good luck !
Jun 04, 2009 | Compaq Evo Notebook N115
Sound problem
pls i don;t have sound drivers for my acer travelmate 2700. could you pls fixya for me? thanks
Aug 05, 2008 | Acer TravelMate 2700 Notebook
CONNECTING TO WIRELESS INTERNET
hi check u install your wireless lan driver are correct.
check your dns and ip setting if they needed to connect internet.
othyerwise set it to automatically.
check your router and wlan configure properly.
Mar 25, 2008 | Compaq Evo Notebook N115
Compaq Evo Notebook N115 Logo
203 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
