Question about Samsung PCK5315RX TV
No sound or picture
This unit came in with no sound or picture do you have any ideas?
  • fabriziogg Apr 17, 2009
    I have a Samsung PCK5315R rear projector. I paid a tv repair guy to come check it out and told me that it was the "power source". Try leaving your tv on for a long time, the power source should then "heat up" and eventually you'll get an image. You probably dont have any sound because the settings are either on dvd or vcr or video game (I also didnt have sound). After the tv tech had the tv on for a good while (15-30 min) the picture came on, then I had to change it to (cav-tv) then the sound blasted and I had to lower the volume. The estimate he gave me was from 380-400 bux telling me that the power source was about 90 to 100 so Im trying to see if I can find it cheaper on line so that maybe he can lower the labor charges. I hope this helps friend. Thank you.
    Genius:
  • 1,694 Answers
1)Check for CRT coolant leak on main PCB's. 2)Check any/all fuse devices. 3)Measure power supply source voltages. 4)PVAT! Pull chassis--look carefully for bad solder connects,esp. regulators. Please let me know how you did.
Posted on Oct 03, 2007
SOURCE:
Cant hear the games when playing sega the static buzzing sound over powers it
I know nothing about the unit but it sounds like a bad ground on one of the sound cables.
Aug 24, 2014 | Video Game Consoles & Games
Tv comes on, but no picture or sound
you need this unit to be service, we need to remove back cover and trace ckt board for possible defective parts and lost contact. just advice we can do this.
Apr 13, 2010 | Hitachi 50UX57B 50" Rear Projection...
Fuzzy picture wen connecting macbook to tv
Sounds like bad Earths to me... Is it better if it is OFF, the AC/DC power supply? If so then yes, bad earthing between units and earth.
Feb 03, 2010 | Televison & Video
30-45 min into use the picture goes black
Sounds like something may be broken try calling the place where you bought and if the warrenty is still in effect you can get a replacement
Nov 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Mitsubishi CS-31303 will not power on.
I have Mitsubishi TV CS-31303. It has transient issues. At turn on, it shows horizontal fringes for some time along with picture, then single horizontal line only and then after some time finges at the 1/3rd bottom and then clear full picture. After some more time the clear picture turns into horizontal fringes at the bottom 3rd of the picture and picture rolls and then again the picture is very clear. Some one said that there is an issue in the signal PCB. Where is it and what componets are at fault. I do have service manual which shows circuit diagrams.
Oct 28, 2008 | Televison & Video
No sound or picture
first check  if it is in AV  mode.  if true then change it to TV mode.  problem will solve ...
  In rare cases  inside the TV  board  chroma ic may gone if there are  2 ic's.
micro controller may gone if there is  only one ic...
thank u
Sep 30, 2008 | Samsung TXE2546 25" TV
PROSCAN TV
Hi
the ticking sound is coming out from the flyback that is high voltages!!! if you on the unit is there a picture coming out? or sounds coming out from speaker?
Thanks!
Jul 02, 2008 | Televison & Video
Zenith System 3 25" no audio picture ok
If you have satellite try unplugging satellite receiver. If doesn't work you probably have a audio output ic bad inside the set.
Dec 31, 2007 | Zenith Z25A66R 25" TV
No sound on digital channels
Reset the unit . Switch off, pull the power plug of the wall receptacle and wait for about 1 min. Then plug it back in and problem will resolve. Check if you have the latest version of firmware
Nov 25, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Televison & Video Logo
98 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
