Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Putting windows xp into standby
When i going to put my pc into standbye i can't a window opens up stating this.... The device driver for the 'standard 101/102-key or mircosoft natural ps/2 keyboard' device is preventing the machine from entering hibernation. Please close all applications and try again. If the problem persists, you may need to update this driver.
  • 34 Answers
Go to Microsoft website and download current driver.
Posted on Oct 03, 2007
Windows xp no audio device
Open the Control Panel.
Go to System Icon, press
Pick Device Manager and look for yellow balloon, this should be near the sound folder. This is where the fault lies, usually in a faulty driver.
Download a new one from Hp.com, by putting in your pc model number and look for audio drivers and downloads.
Mar 05, 2015 | HP Pavilion Computers & Internet
Sleep/hibernate mode
Hi, If the computer seem to wake from sleep mode for no reason? Some device settings can cause the computer to return from a power savings state when not expected. If the computer is using an optical mouse, changes in light can cause the computer to wake. Network activity can cause the network hardware to wake the computer, especially when the network is always on (like cable and DSL connections). High Definition Audio audio may also cause the computer to wake from sleep mode. Use the following steps to prevent the these hardware devices from waking the computer:
  1. Click Start c00847244.gif , and then right-click Computer .
  2. Select Properties , and then click Device Manager in the left panel of the window.
  3. Click the plus sign ( + ) next to the device that needs to be adjusted. If you are using an optical mouse, select Mice and other pointing devices . If the computer is using an "always-on" connection, click Network Adapters . To check the high definition audio, click Sound, video, and game controllers .
  4. Double-click the name of the device to open a Properties window.
  5. Click the Power Management tab, and remove the selection from Allow this device to wake the computer . Figure 6: Power management tab for a mouse c00851648.gif NOTE: If you prevent the mouse from being able to wake the comuter, wake the computer using the Sleep button on the keyboard or from the power button on the front of the computer.
  6. Click OK , close the windows that are open, and then restart the computer.
  7. Click Start c00847244.gif , and select the Sleep/Standby button to see the problem still exists: If the problem still exists, go to the next Step.
  8. Disconnect all non-essential connected devices (printers, scanners, USB drives).
  9. Restart the computer with only the original mouse, monitor, and keyboard connected. If this resolves the sleep/standby problem, one of the connected devices was causing the problem. Replace one device and test to see if the problem occurs again. Continue adding devices and testing until the you find the device that is causing the problem.
If you have already tried all the above steps, you can try the steps below: Many software components start up automatically and run without being seen. Most of these programs are not necessary to the work performed on a computer, but can interfere with sleep/standby mode. For troubleshooting purposes use the following steps to prevent programs from starting when Windows is first opened.
  1. Click Start c00847244.gif , and then type msconfig into the Search field and then press the Enter key.
  2. The System Configuration Utility appears. Click the General tab, select Selective startup , and then and remove the check from Load startup items . c00847247.png
  3. Click OK to accept the changes and restart the computer.
  4. After completing these steps, Windows opens using Selective Startup. A small reminder may appear when Windows restarts. Select Don't show this dialog again and click OK to prevent the reminder from re-appearing every time the computer is restarted.
NOTE: To undo the changes made in this process repeat the steps above and replace the checkmark next to Load startup items .
  • If disabling Load startup items did not resolve the suspend problem, go to the next step.
  • If disabling Load startup items resolved the suspend problem, enable one startup item and test to see if the problem occurs again. Continue enabling startup items, until you find the software task that is causing the problem. Remove or update problem software.
If the problem still exists, go to the next Step. Upgrading the BIOS and keyboard software If the sleep button on the keyboard still does not work, go to the HP Software and Driver Download page , enter your computer model number into the field provided, and install any keyboard and BIOS updates for Windows Vista. Should you require any further assistance regarding this issue or any other computer related issue in future please feel free to contact get back to us, we will be more than glad to assist you.
Regards
Malik Khan
Feb 01, 2008 | Microsoft Windows Vista Ultimate Edition
No audio
Driver: Small piece of software that allows the Operating System to communicate with a device.
Windows XP and Windows 7 are two examples of an O/S.
The audio chipset is the device in this case.
http://support.fujitsupc.com/CS/Portal/supportsearch.do
Click on the blue underlined - Audio - under the appropriate Operating System you are using.
Since you didn't state what O/S you are using, I am going to choose Windows XP Home for an example.
Click on the blue underlined Audio, under the Windows XP Compatible Drivers subheading.
Under the Fujitsu Software License Agreement, click on Accept.
A small window will come up on the right -
Opening S5582_AUDIO_WINXP-HOME.exe
Click on Save File.
Another small window will come up on the left.
Let the file fully download. Then DOUBLE-click right on the file name.
If a Microsoft 'squawk box' comes up ignore it. Click on Run.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
If you are not asked to do so restart your computer.
(Start > Turn Off Computer > Turn Off )
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 19, 2012 | Fujitsu LIFEBOOK S5582 PC Notebook
Error: GetFileText. BrowseIt. Permission Denied is popping up constantly
Let's put the computer in clean boot state and check if any third-party program is causing this issue.
Putting your system in clean boot state helps in identifying if any third party applications or startup items are causing the issue. If yes, you may have to contact the program manufacturer for any updates or uninstall and re-install the program.
Here's the article you may refer to for steps with reference to the same.
Use this link if you are using Windows XP:
How to configure Windows XP to start in a "clean boot" state
Note: After troubleshooting, make sure to put the computer to start as usual as mentioned here:
To configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows XP to start normally.
a. Click Start, and then click Run.
b. Type msconfig, and then click OK. The System Configuration Utility dialog box is displayed.
c. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
d. When you are prompted, click Restart to restart the computer.
Apr 15, 2011 | Microsoft Windows XP Home Edition
Hi my laptop had sound before and now it doesnt i need help putting it back on its a toshiba satellite L25 and it runs on windows XP i had to restart everything my wireless internet was gone and my sound...
go to control panel. using classic view, choose sound and audio device. from the dialog check whether the system speaker it in mute state. If its not in mute state. There is another option, u restore ur system back . click start, run, type restore in the space, enter, double click on the restore icon, it wil open the restoring points you have on your system. choose the date that u know that all the drivers are working well, then ok. Your system will restart. Thats all very simple.
Nov 17, 2009 | Toshiba Satellite L25-S119 Notebook
Getting my video card to work
Hello , Pleas don?t Change any setting in your VGA port Adapter Windows will automatically disable your old or integrated Graphique Card, so set default setting in your configuration then reboot your pc
Jun 12, 2009 | HP Computers & Internet
My speakers work but my headphone jack won't
The Solutions that will mostly work :
1) Go to sleep mode - wake up ! - tada !! the headphone jack will work again .. I know it sounds crazy.. i had the same problem.. (ie speakers onboard worked while headphones jack didnt work) usually restarting solves any problem, but this time even a restart did not worked while putting the laptop on standby(sleep) mode and waking it up worked !!
2) If the above does not work, uninstall the sound drivers from device manager - restart the computer - then let windows detect appropriate drivers by itself. Sometimes the Sigmatel drivers(which are provided by manufacturer) do not work well compared to windows vista's HD sound drivers. May solve the issue... Do not worry doing this, in the worst scenario you can always download and reinstall the dell drivers from dell support page.
Please update on sutarianiral@gmail.com if the problem gets solved..
Mar 01, 2009 | Gateway MT6707 Notebook PC
Windows XP Pro hangs on resume from standby or hibernate
There are many reasons this can happen, and unfortunately very difficult to pinpoint the issue in a particular case.
1. In your system BIOS there is usually two sleep mode (power states) you can select. It is Usually set to S3, change it to S1 (or vice versa), and disable wake on LAN (if available) unless you need it
2. Attempt a clean boot and see if some background startup item or service is causing the issue. see this article for troubleshooting startup items
3. Make sure you drivers (especially chipset, network, video and sound) and BIOS are up to date.
4. Disconnect as many things as you can (boot with just your keyboard, mouse and monitor) try a different mouse and keyboard.
I hope you find the cause, also check in Event Viewer to see if there are corresponding errors
Feb 05, 2009 | Microsoft Windows XP Professional With...
My sound
Problem C-Media AC97 Audio device no open?
Dec 06, 2008 | HP Compaq Presario SR2150NX PC Desktop
Bluetooth device software
Not sure whether the Operating System in your Notebook is Vista or XP.
I am providing you the steps which can be performed in both windows XP and Vista one after the other. Try these steps according to the Operating System you have installed in your notebook :
Uninstalling and rienstalling Bluetooth Hardware drivers from your Notebook in Vista :
Click on the Start Menu and type Device Manager in the search field. Click on the Device manager link in the results.
The Device Manager opens in a seperate window.
In this, click on the [+] mark next to Bluetooth Radios to expand the tree.
Right click on any device which states 'HP Integrated Module with Bluetooth' and select Uninstall.
Restart the notebook once this process is done.
Cancell ro close any window which states New Hardware found.
Download the Bluetooth hardware drivers for Vista from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38167.exe
Save the file in the Notebook and double click once it is saved to install the drivers.
Uninstalling and rienstalling Bluetooth Hardware drivers from your Notebook in XP :
Right Click on My Computer and select Properties in the list.
Now go to Hardware tab and click on the Device Manager button.
Device Manager window opens in a seperate window.
Now click on the [+] mark next to Bluetooth Radios to expand the tree.
Download the Bluetooth hardware drivers for XP from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32315.exe
Additionally, perform Windows Update so that any updates available from Microsoft for that particular hardware device will be installed.
Hope this helps...
Aug 14, 2008 | HP Compaq Presario V6000T Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
