Question about Apple iPod nano
My first gen nano, displays apple logo, nothing else
I recently swapped screens on my nano. it lit up, but did not display anything. then i took it to the local apple store, they plugged it in, it worked perfectly. since then i swapped the screen again, and now it shows the apple logo, but nothing else. it will play music, but i am frustrated for losing my info. i have tried to reformat, resync, and reset it, and i have the latest copy of itunes, but nothing has worked. any help?
    Problem Solver:
  • 30 Answers
Something has bin tuched inside and fused it maby need a new ipod try taking it bk to apple store p.s try getin a cover next time then you wont need new screens
Posted on Oct 18, 2007
SOURCE:
Ipod nano 3rd gen has frozen and wont do anything ...help!
Make sure your iPod is not on hold by sliding it on then off again.
Hold the Menu and Center button until you see the Apple logo on your screen and it should restart and come on back to normal.
Dec 17, 2009 | Apple iPod nano 3rd Generation
Tip
IPod Nano/Video/Touch Resetting
One day your using your iPod and all of a sudden, boom. It turns off and refuses to work or read by your computer.
You might get the apple logo, but thats where it ends. In this case, theres a few things that can probably bring you device back and kicking.
iPod Nano/Video(Classic)
6th Gen Nano
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
4th and 5th Gen Nano/Classic/Video (CLICK WHEEL VERSION)
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
In case the reset does not work, the alternative is to connect the device in disk mode and restoring it.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. zero77cool.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
This will enable a black/white display. Restore it using iTunes.
If the above doesnt work, then Im afraid its time to repair your device.
Note: images and part of help copyright © 2011 Apple Inc. All rights reserved
on Mar 13, 2011 | Electronics - Others
My Apple ipod display screen shows lines (coloured one),, cant see menu or anything..but the songs play
Sounds like a bad display. You can get replacement displays here http://www.ifixit.com/iPod-Parts/iPod-Nano-Gen-2-Color-Display/IF199-000
-=/ Daft Tech /=-
Oct 24, 2009 | Apple iPod nano
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
My fourth gen ipod nano still plays music but the display screen does not work. The screen is grey. I tried to charge it and still nothing happens.
If you hold the middle button with the menu button for roughly 20 seconds the Apple logo will show and the device will reboot. Wait for it to reboot and it should be ok.
If this doesn't not resolve the problem it could be possible that the screen is damaged in some way.
May 17, 2009 | Apple iPod nano
My ipod nano 2nd gen's screen won't display anything..
I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
Dec 06, 2008 | Apple iPod nano
Nano screen
why wont it charge
Jun 21, 2008 | Apple iPod nano
Frozen Ipod Nano
  1. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  3. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  4. Connect it to your computer.
  5. In iTunes, select Restore to Restore the iPod firmware. This erase everything on the iPod.
Dec 04, 2007 | Apple iPod nano
Ipod nano 1 gig 1st gen, screen on, then goes out repeatedly.
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If you need more assistance let me know. Good luck.
Nov 03, 2007 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
