Question about GE WSXH208A Front Load Washer
Elastic eating front load washer
I have a Frigidaire front load washer and I wash my clothes on the Delicate cycle. The machine takes the elasticity out of underwear, socks, pants etc. I put my clothes in wash bags and the problem still occurs. Furthermore, stains don't come out 100%. I bought the washer to save on water but must say I regret it. My older washer washed ten times better.
    Problem Solver:
  • 15 Answers
Check the inside drum vanes. Sometimes the vanes may crack and grab certain items.Next check the front of the drum and tub for any loose items like wires from bras or curtains sometimes these may get stuck in the drum or vane and cause this problem.Also check your soap make sure there is not alot of suds this is my number one problem with these machines.H.E. soap is best but watch liquid tide it's been sudsing alot.
Posted on Oct 10, 2007
Samsung front loader washing machine power cut out mid load
If by turning off the power you mean you hit the power button .... try unplugging the machine for about 15 seconds and then plug it back in ... this may reset the machine. If not you may want to call Samsung ...
http://www.samsung.com/au/info/contactus.html Hope this helps!
Nov 25, 2013 | Samsung WF337AA Front Load Washer
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Our Fisher and Paykel clothes washing machine, model # WL26CW2 has a clear colored elastic band that attaches from the top frame of the washer to the tub that came detached. I see there are several spaced...
this usually happens when the load is one sided for a short time if the rubber has not split then you need to take a 5mm steel bar with one end turned at 1 inch to 90 % so you can push or pull it back to the hook or angled piece of bracket eric
Dec 22, 2017 | Fisher and Paykel WL26CW2 Top Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore front load washer that will not spin all the water out of the clothes. After it finishes I have to run it through a rinse spin cycle and it does fine. The machine is only 14 months old
The first thing to check is probably the filter at the bottom of the machine. I'm not sure about this particular model, but the usual thing to do is to remove the machine's front lower panel - i.e. the panel at the front of the machine, closest to the floor.
You will probably find a little drawer or door, just a couple on inches in size. If you open it, you may find some lint, a couple of elastic bands, and enough coins to buy a beer. If so, it's the coins that are causing the problem! Take out all the stuff, close the little door, put the panel back on, and everything should run fine.
I hope that helps. Good luck!
Oct 09, 2010 | Kenmore 44042 Front Load Washer
My Amana Washing machine ruins underwear elastic waistbands
Reduce the actuator speed to slowest/delicate speed. Good luck
Jan 10, 2018 | Amana NAV5800A Top Load Washer
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Takes 3 hours to wash a load of clothes
make sure you are using soap the is for front loading machines. (he)
Aug 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
GE WSXH208A Front Load Washer Logo
141 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
