Rank: Guru
Rating: 86%, 378 votes
white film generally shows that there is not enough salt in the dishwasher, this is not normal salt like on your meal, you buy this from the detergent section of the store, add salt through the part where it says "S" unscrew the cap and put about 2 cups of it in, while filling with salt water will overflow out of the same place, this is normal
this will start to work after about a wash or so
if the salt is fine then check the heater on the machine, make sure its warming up etc
if i have helped please rate me
Comments:
Oct 04, 2007
- you put salt in like you put wash powder in it, maybe less often, you do need it to run properly
use salt all the time, its not expensive
check the manual there is always a place for salt to go, it may differ for other models and machines, you just have to look, it does go somewhere trust me keep looking
jet dry is not the solution in your case, salt is the only answer
