Sony Grand WEGA KDF-50WE655 50 in. Rear Projection HDTV Television
Problem for Sony Grand WEGA KDF-50WE655 50 in. Rear Projection HDTV...
Sony 50 Wega LCD flashing red light
By kmahorney on May 01, 2009
I have a sony 50 wega LCD it powers on then turns off with the standby light flashing red. Does this mean I need to replace the blub?
Thank You,
Kevin M
Best Solution
posted on May 01, 2009
Very Helpful)
rylee_smith
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 1027 votes
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Sony Grand WEGA KDF-50WE655 50
Questions and Unsolved Problems for Sony Grand WEGA KDF-50WE655 50
Do you recommend Sony Grand WEGA KDF-50WE655 50 in. Rear Projection HDTV Television?
Answer
Answer
The outside of the screen looks as though it has "finger print smere" on it. I cleaned... (More)
Answer
block box in upper left hand corner won't go away...tried re setting the closed captioning...that... (More)
Answer
buzzing sound for a couple seconds when trying to turn on, then tv shuts off...no picture or sound.... (More)
Answer
3 yr old Sony Wega KDF-50WE655 with bluish tint covering picture. Help!!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
