Question about Toshiba Satellite A85-S107 Notebook
Toshiba Notebook Everytime you hit the Q the #1 shows on the screen, its the same way the entire way across the top row.
  • cindylou3610 Oct 03, 2007
    Thank you for your input but this didn't work, now after trying this if we hit 8 we get 5.
    Thanks again, still open for suggestions.
    Scholar:
  • 132 Answers
It sounds like you have the numeric overlay turned on. Hold down the FN key and hit F11. see what happens
Posted on Oct 03, 2007
Why can I not see the top of page to access toolbar across top
Upgrade to a newer OS. XP is no longer supported by microsoft.
Apr 04, 2015 | Microsoft Windows XP Home Edition
MSI 760gm-p21(fx) MB, JFP1 AND JFP2 PINOUTS I NEED TO SEE A DIAGRAM SHOWING ME EXACTLY WHERE TO PLUG the cables on the MB
http://www.msi.com/product/mb/760GM-P21--FX-.html
Hover your mouse cursor on the Download tab.
(Overview/ Specification/ Download/ Support/ Where to Buy)
In the drop down list click on - Manual
On this page under the subheading Download, click on the blue -
M7641v3.0.zip
On the next page click on the country name nearest yours.
Motherboard User Manual.
This is a Zip file. If you do not know how to open a Zip file, please state in a Comment, and I will guide you.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is divided into two headers on the motherboard.
This you have stated, JFP1 and JFP2.
(Junction Front Panel 1, and Junction Front Panel 2)
JFP1 is for the Power On switch, HarDDrive activity LED, Reset Switch, and a two wire Power On LED.
JFP2 is for an internal speaker/buzzer, and a three wire Power On LED. (Dual color)
JFP1:
4 pins across the Top row.
5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is reserved for the factory to use.
D) Pins 2 and 4 are for a two wire Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO pin 10.
JFP2:
3 pins across the Bottom row.
Starting on the LEFT side coming across to the Right, Top row;
Pins 1, 3, and 5. There is NO pin 7.
A) Pins 1, 3 and 5 are for a dual color Power On LED.
Pin 1 is for the Negative ( - ) wire.
Pin 2 is for a Yellow, or Orange part of the dual color Power On LED.
Pin 3 is for a Green part of a dual color Power On LED.
B) Pins 2, 4, 6, and 8, are for a speaker/buzzer.
Pin 2 is for the Negative ( - ) wire of a speaker.
Pin 8 is for the Positive ( + ) wire of a speaker.
Pin 4 is for the Positive ( + ) wire of a buzzer.
Pin 6 is for the Negative ( - ) wire of a buzzer.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 28, 2012 | MSI Computers & Internet
My toshiba satellite M645-S4045 doesn't want load up the system! How can I turn it on in the safe mode?
To access safe mode in Windows: From a completely powered down state, turn on the computer. At the Toshiba splash screen, start tapping the F8 key (top row of your keyboard). This will load a menu selection that has safe mode. Use the arrow key to highlight safe mode and then hit return. A mess of text will load on the screen and then a few moments later the computer should ask you to confirm you want safe mode.
I hope this helps
Sep 01, 2011 | Toshiba M645S4045 14" Notebook PC Charcoal
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Toshiba a135- screen is temperamental. sometimes it works other times it doesn't. now would that be a problem with the lcd cable or the lcd inverter?
It is often a cracked cable, or a loose cable, the inverter tends to fail quickly either with no warning or flicking, and flickering then failing. Sometimes if the Video card, is in a mini PCI slot it may need to be reseated. Often though it is the LCD itself, as the Driver Row/Column drivers pack up, this is evidenced by lines, dots colors, spreading across and down the rows and columns.
Feb 25, 2010 | Toshiba Satellite A135-S2276 Notebook
Changing the brightness on the screen
look across the top row of keys you should see a round sort of sun symbol with nothing inside, along side that another one the same, but filled in, or something like this, theses or the like are used with the Fn Key to brighten & darken the display
Feb 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Rows of Lines across top of screen
I decided not to repair, but use the 16:9 feature on the remote control.
a kind of letterbox look, not bad at all.
I'n not going to spend money, replacing the vertical output ic circuit's bad capacitor or vertical power supply for bad cap.
Jun 11, 2008 | Toshiba 24AF43 24" TV
Red, green, and blue rectangular "chads" or squares across top of screen
Hi there, this is easy thing to fix. Its LDV cable. This is the Cable which goes from the main board on to the screen. Un plug the cable from the screen side., then push the cable back. Make sure cable sits in .
This will sort all the problems with the picture,i.e colour problem , picutre squring up and many more things.
Regards Sam
Sep 28, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Toshiba Satellite A85-S107 Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
