The light switch and dimmer have become inoperative on my 36" VIKING WALL RANGE HOOD PROV 36W.430, to the point that the lights can not even be turned off. I am eager for some information on how to even access the switches for removal and repair. There are no screws visible to remove any of the shrouds. THANKS.
SOURCE: Viking Range
Juliac, the burner valve switch for that burner is either shorted or grounding out. Each burner control has a valve switch that controls the power to the igniter. Sometimes they just get full of gunk and short. Part number is PA020015. Catriver...post back.
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
SOURCE: Viking Range VGIC4856GSS
Goto this site. http://www.3wire.com/foodservice/?OVRAW=northern%20parts&OVKEY=northern%20part&OVMTC=standard&OVADID=6566743522&OVKWID=55119092022 they should help you out.
SOURCE: My Viking range top grates are dirty
viking advises using nothing but warm soapy water. grate polish works very good to bring that deep black shine to the grates again
SOURCE: Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through
Viking themselves whether you want them to replace it or you yourself
replace it, you can get the part through them.
Benjamin
