Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Nortel IPSEC VPN unable to connect via a Belkin N1 Wireless Router
I recently bought a Belkin N1 Wireless router, F5D8231-4 v4000, to replace a Belkin 802.11b router. Hooked everything up and got it running with no problems, except now my Nortel VPN client will not connect for work. I am able to access the Internet from the laptop but when I try to connect the VPN client it times out. I have put the Laptop in the DMZ and I have disabled the firewall but nothing works. Also I can ping the VPN switch via the domain name and IP address. Belkin Tech support has been useless so anything anyone knows would be grately appriciated!
  • 10 more comments
  • kmbdcb Oct 05, 2007
    There is no Port Forwarding optoin on this router. I have tried to open the upd port 500 and 10000 on the router firewall but that did not work. I have also disabled the firewall and placed the laptop in the DMZ, both solutions did not work either. I think it has something to do with the IPSEC pass thru within the firmware but I cannot find a way to change a setting for that and I have to latest firmware update. 3 days ago this was escalated to Belkin Tier 3 support but no call from them yet.
  • kmbdcb Oct 14, 2007
    I was finally able to get Belkin Level 3 Tech Support to call me. What we ended up doing was taking my Old 802.11b router and connecting to the Internet with it. Then changed the IP address on the N router. This now made the N router function as just a wireless switch on the network. Once we did that everything worked fine. I asked the guy what would I do if my old router dies and he said Belkin would send me a hard wired router. Sounds like they have seen this before and they also know it is a problem. Anyway I am up and running again so that is a good thing!
  • kmbdcb Oct 28, 2007
    If you read the comments I have posted I have done all of the optoins you listed. None of them worked. Also I have spoked with Belkin and we came up with a work around and I am thinking this is a known issue with Belkin since the Tech that finally called me seemed to know exactly what to do and when I asked about what happens if my old router fails he said Belkin would send me a hard wired router for free.
  • mizscarlett Dec 16, 2007
    can't port forward with my belkin n1 router.. Barbara Boyden
  • kmbdcb Jan 30, 2008
    Thanks for the info! I just had to go out and buy another hardware router because my other one had died. Nice to know though they finally fixed the problem!
  • Mikael Henriksson Mar 10, 2008
    This router is a pile of junk. I cannot use the version 4 firmware since I have a version 2 router and there is no firmware that supports vpn passthrough yet.
    I tried getting hold of support but they cannot help me. What should I do?
  • kingboat May 06, 2008
    I bought belkin N1 Wireless router and set it up but, the problem I have is only one user in my office can connect to our remote VPN server, the rest can not.
    I'm using this device as my internet router, the older one I was using was Linksys and I didn't have any problem whatsoever with connecting to VPN.
    Can anyone help????????
  • jay5308 Jun 22, 2008
    It's June of 08 and I'm still waiting for a solution from Belkin for the N1/VPN connection problem. Anything moving on this?
    Jay Hartigan
  • kmbdcb Aug 06, 2008
    Finally got around to upgrading the firmware, that fixed up but now my company uses different VPN client so it was not an issue anymore. Thanks for finding it!
  • Drucifer Oct 15, 2008
    I had the same problem connecting to my corporate network via Cisco VPN through a Belkin N1 wireless router (model # F5D8231-4). Had similar useless support from Belkin, but got it to work thanks to the suggestions listed here, namely:
    1. Disable the Firewall on the router
    2. Upgrade the Firmware to F5D8231-4 WW v4.00.18
  • Anonymous Oct 23, 2008
    Just upgraded from old belkin 802.11G modem/router to N1 vision modem/router. Everything worked fine until attempting to connect to work via Nortel VPN. Cannot connect to VPN at all. Changed back to old router working fine. Attempted port fwd, DMZ etc... all failed.
  • kingboat May 11, 2010
    I tried upgrading the firmware but it was stop suddenly and the error message I got was; you are trying to install an incompatible software. The router rebooted and went back to the same old story.
    Please am stacked and can not do anything, frustration is setting in now.......need your help asap
    Am using N1 Wireless Router F5D8231-4 Ver 5000
StarCatZ,
I was just talking to the Tech Support in Belkin and I have to say that I focking hate with a passion. I am in your same position (ver.2) and all they could tell me is that they dont support VPN and that they cant help me. I am so pissed. They are so damn dumb it just makes me mad.
I am going to try and get mine replaced for a newer version with hope that that might fix my issue. good luck!
Posted on Mar 24, 2008
U Can open the Web Interface Of the Router by Typing the IP Address of the Router which is 192.168.2.1...
Select Virtual Servers under Firewall Option Which is Towards the Left hand Side of the Belkin Router Setup Page.
U can Get the Port Nos. of that Application.
Even if Not Working U can Update the Firmware Of the Router Which is Available in http://www.belkin.com/support/article/?lid=en&pid=F5D8231-4&aid=5927&scid=0 & U Can Use the New Beta Version Of 4.00.17....
Even Still If Not Working.,try to Disable the Firewall on the Router Which is in the Router Setup Page..
Even Still if Not Working Getit Replaced.
Venky
Posted on Oct 27, 2007
  • 3 Answers
Hey buddy , Try doing the port forwarding OPTION ON BELKIN ROUTER...GO TO THE SCREENS OF BELKIN BY TYPING THE ADDRESS 192.168.2.1 ..GO TO THE PORT FORWARING OPTIONS..TRY TO OPEN ALL THE PORTS. OR IF U KNOW WHICH PORT TO BE OPENED..WELL AND GOOD...PLS LET ME KNOW IF IT WORKS...GOOD LUCK
Posted on Oct 05, 2007
SOURCE:
How do I enable IPSEC Passthrough on this wireless router?
look in the settings of the Belkin to see if you can enable VPN Pass-through.
Try disabling some of the firewall functions on the belkin to isolate the issue and turn the rest back on.
If for some reason this model doesn't work even after the above, try changing the VPN client's connection settings,there are only two to choose from... (click modify on your connection entry, go to the Transport tab > then choose from:
IPSec over TCP and IPSec over UDP (port 10000)
Sep 30, 2013 | Belkin (F5D7230-4) Router (587009)
I am having difficulty connecting to Cisco VPN, could the router be interfering with this
The router could be blocking it. On your belkin router, check to make sure that ipsec vpn pass through is enabled.
Mar 18, 2011 | Belkin Basic Wireless Router
I have tried to connect to my work server via vpn but get error message 800 everytime. 'Error connecting to VPN connection Connecting to .................. using ?WAN Miniport (L2TP)?.. Error 800. The...
First thing to try is making sure you have the latest firmware on the router. If you have not logged into it before you need to type http://192.168.2.1 in your browser address bar and log in when prompted. The router by default does not have a password set so it might be worth setting one in system settings. You should find on the menu an option to update the firmware. Read the screen should guide you how do this. If the firmware is up-to-date and you still have a problem try disabling your firewall on the pc to see if it's getting in the way. Don't leave the firewall off if you find it's causing the problem you just have to work out how to configure it to allow the traffic out. The route should allow this traffic out by default.
Dec 02, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 F5D8231-4 V3000
are you running the Cisco VPN client from home, where this Belkin is your gateway and connecting to say your work?
If so, have a look in the settings of the Belkin to see if you can enable VPN Pass-through.
Sep 07, 2009 | Belkin (F5D8231-4) Wireless Router...
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to [email protected]
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Belkin - N1 Vision Router Unable to connect to the interste
Did you use the pass key to connect? If you are using the wifi you have to go to here 192.168.1.1 with browser type admin for username and admin for pass and config the the router. To make life easy just use a cable ie Ethernet..
Oct 31, 2017 | Belkin (F5D5231-4) Router
Belkin N1 Vision (Part # F5D8232-4) and VPN problem
I hade the same problem with mv Cisco VPN v5.0 and Belkin N1 router (F5D8231-4 v4...). I could only solve the problem with a new firmware (f5d8231-4 ww v4.00.18 at http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8231uk4&aid=9419&scid=0 ). I think this is a general firmware issue at Belkin. Good luck.
Feb 27, 2008 | Belkin N1 Vision Router
Nortel Extranet VPN using ESP IPSec
Step 1 Go into the web-based configuration on the router (enter 192.168.0.1 in your web brower). Enter username (admin) and password (blank). Step 2 Click on Advanced at the top and then click on Applications on the left side. Step 3 Check Enable Step 4 Enter a name (i.e. Nortel). Step 5 Enter 500 for Trigger Port (500 - 500). Step 6 Select Both for Trigger Type. Step 7 Enter 500 for Public Port. Step 8 Select Both for Public Type. Step 9 Click Apply and then click on Continue when prompted.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
5,622 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
