Question about HP Officejet 5610 All-In-One InkJet Printer
Error code: 0xd0620230
Cartrage stop moving and all power ,copy ,scan and fax buttons are lightening
  • 5 more comments
  • Anonymous Dec 16, 2007
    I had a simiiar problem with my printer which states the error code :oxdo620230 . But code number stated are not the same. the machine state power problem.
    I tried to put off the the power restart it once more but the problem still persist. So please help me our with a possible solution.
  • AntekSkva Mar 02, 2008
    When trying to copy a document from the glass, printer begins to print and about one-third of the way, stops and gives error code "0xd03620230 Reset Power" I then unplug power and re-plug. The paper is ejected with only partial printing. What is the solution?
  • AntekSkva Mar 04, 2008
    Tried most everything to get rid of error 0xd0620230 Reset Power. Changed cartridges, now I cannot print anything withoput getting the same error. Can't even print an alignment page. Any help?
  • tapha fall May 27, 2008
    cartrage stop moving and all power ,copy ,scan and fax buttons are lightening
  • rahulshah001 Jul 21, 2008
    change black cartridge
  • Anonymous Aug 01, 2008
    HP 5610 all in one
    errors:
    - 0xd0620130 reset power
    - 0xd0620230 reset power
    - 0xd0620330 reset power
    What's it?
    thank you
  • khullar15 May 23, 2009
    I am also facing the same problem with my 5610 printer.I am having both new genuine HP cartridges but still getting the message as Error:0xd0620130 or 230. can anybody tell me the solution at [email protected]
Hp dj office jet 5610 printer - error 0xd0620330 reset power
Posted on Sep 29, 2009
  • 30 Answers
Fiend your solution direct from hp. Here is your solution...
error code: 0xd0620230 - 237c944.jpg
http://www.hp.com/printer/prob676ijt65/solution
732
Posted on Feb 27, 2009
Other Users Have The Same Problem Comment by AntekSkva, posted on Mar 04, 2008 Tried most everything to get rid of error 0xd0620230 Reset Power. Changed cartridges, now I cannot print anything withoput getting the same error. Can't even print an alignment page. Any help?
Comment by AntekSkva, posted on Mar 02, 2008 When trying to copy a document from the glass, printer begins to print and about one-third of the way, stops and gives error code "0xd03620230 Reset Power" I then unplug power and re-plug. The paper is ejected with only partial printing. What is the solution?
Comment by Guest, posted on Dec 16, 2007 I had a simiiar problem with my printer which states the error code :oxdo620230 . But code number stated are not the same. the machine state power problem.
Posted on Apr 21, 2008
  • 45 Answers
Follow this link and check what happens http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=441125&dlc=en&lang=en
Posted on Oct 04, 2007
  • 3 Answers
This error is a 1.wrong ink cartridge installed to the printer 2 not genuine Hp carts and sometimes a refilled inks installed to your printer.
3.this is a remanufactured printer.
4 sometimes if the ink carts are already expire try to see the warranty date of the ink carts it is on the ink carts itself.
try this one if it works.
1. you need to turn on your AIO.
2uninstall the ink carts
3.unplug the power cable from your printer without turning off the AIO on the on/off button.
4press the # and 6 at the same time tho' the printer is off.
5plug the power cable back in and don't release the buttons yet until the small screen on the printer becomes blank or off.
6then release after.
7then the semi full reset performs. you need to change the settings and choose a language u want.
8 that is a factory reset.
9.after that if you are prompted with ink cartridge is missing install now the ink cartridges.
10 press the setup button. and its ready to go.
11. if this won't work try to call the support center and they can be able to help you out about that one. but make it sure that ink cartridges are genuine.
hope this helps.
Posted on Aug 02, 2008
    New Friend:
I also had the same problem with HP 5610 Error: 0xd0620230, I just dismantled the printer and found Strip wire for catridge assemly got broken. Tested with good stripwire, then it was Ok, Working succesfully.
Shabeeb, [email protected]
Posted on Jan 28, 2011
    New Friend:
Posted on Apr 29, 2010
I am having the same pblm .Any help will be greatly appreciated
Posted on Aug 28, 2008
I had same problem with no alignment and then an error message saying the problem was "out of paper" load up and push the OK button. A guy at office max said to uninstall the printer and then reinstalling. it did no good and dthis was adfter unplugging the usb cable and holding the two buttons
Posted on Apr 27, 2008
SOURCE:
Hi dear why my mfc8840d can't switch from fax function to copy and scan function
It sounds like you have some sort of printer error, you can try holding the stop button as you power up it will either tell you the error or clear it so you can copy and scan again.
Feb 01, 2010 | Brother MFC-8840D All-In-One Laser Printer
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Canon Error code E803
  1. e803 is a problem with the scanning lamp. Does the lamp light up when you power on or does it go right in to error code?
Jul 23, 2008 | Canon ImageRUNNER 330s Copier
Oxd0620230 reset power
Below is the document that i want you to follow exactly in order to resolve you issue.
CLICK HERE ==>> DOCUMENT
Please let me know the outcome after following the steps.
thank you so much.
adonscott
Jul 17, 2008 | HP Officejet 5610 All-In-One InkJet...
It might be a hardware issue however u can try the following basic troubleshooting steps .
Unplug the power cord from the back of the unit . try to move teh carriage manually .
perform a reset as well .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6
Thanks
May 27, 2008 | HP Officejet 5610 All-In-One InkJet...
SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Oct 26, 2007 | HP Photosmart 3310 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
11,871 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
