Question about Mitsubishi VS-60719 60" Rear Projection Television
Mitsubishi 6071 April 1994 NEED HELP!!!
When i turn this tv on there is no noise and no picture only a funny shaped squiggly cirlce like line kind of like three inches high and 60 inches wide and its blue what could be wrong with this tv. does anybody know?
  • 143 Answers
These sets have bad connections in the picture yokes take the spekerr grill off and front cover move the wires around and see if the pic comes back be careful ok
Posted on Dec 20, 2007
White, squiggly lines on TV screen
This fault is technically called 'retraced lines'. There are many reasons for this fault. It will be best to contact any service technician. If the screen voltage to CRT is abnormal [higher than normal]; this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
One among the post have details about this fault "Retrace lines with picture".
Mar 03, 2015 | Televison & Video
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
My rear projection tv has squiggly horizontal lines in the picture. Sometimes when I turn it off and then turn it back on it goes back to normal but it is steadily getting worse. Any suggestions would be...
I have seen this on quite a few Mits's as they are getting to that age. This is usually related to bad caps in the signal path. I could go into more detail if I knew the exact Model Number (it will start with WS or VS) Example VS-60609. But the caps are usually near the 5v regulators.
Jul 09, 2009 | Hitachi Televison & Video
YELLOW AND BLUE SQUIGGLY LINES ON THE RIGHT SIDE OF THE SCREEN
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Mar 07, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
VS-45607
YOU HAVE THE DREEDED CAPACITORS GOING OUT...AFTER A FEW YEARS-THE CAPS LOOSE THERE PURPOSE AND DEPENDING ON WHAT CIRCUIT THERE IN --YOU WILL SEE THE ASSOCIATED PROBLEM,,,EXAMPLE--COULD BE SOUND ,PICTURE (YOURS) OR VERTICAL(PICTURE CLOSING UP) ETC... YOU CAN HAVE CHECKED BY A REPAIRMAN BUUUUT ,MAY NOT BE COST EFFECTIVE ,,TUNICA
Oct 24, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi 55809
Check the cabel TV or antenna conection first. And check the tv with a DVD player or VCR too if work thats a problem.
Some TV forget the settings after a power lost, so try to set the stations again.
Nov 11, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi HD 65" thin squiggly line in upper right corner that moves
Is the problem there on every source? DVD playback ok?
Suspect signal source  box.
May have bad connection since move.
Is the problem same on every channel,if source is cable direct?
Please provide more info if more help needed....T.
Oct 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi Vs-6071 Picture
replace the signal board (one with all the rca's on it) and not the main board if a plain antenna works OK
Jun 05, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi VS-60719 60" Rear Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
